| A4 (B5 Platform) Discussion Discussion forum for the B5 Audi A4 produced from 1995-2001 B5 FAQ |
#1 | ||
2007 Volkswagen TouaregMy Garage Join Date: Jun 2008
1996 Audi A4 2.8 1972 Datsun 510 |
#2 |
Tech Guru
![]() Join Date: Oct 2002
Timing belts do not have a break-in period. Is it too tight?
4Driver4 Growing old is mandatory; growing up is optional. 2005 A6 Sedan Q 3.2 (wife's whip) 2000 A4 Avant Q 2.8 (daily driver) 1980 VW Scirocco (mid-life crisis car) 1983 Mazda RX-7 (revolutionary sports car) 2003 Mini Cooper S (just because) 1995 Mazda Miata, Superdupercharged(anti-Audi) 1999 Mazda Miata SSB (track beotch, no plate) 2003 GMC Yukon Denali XL (the anti-earth) 2004 Dodge Dakota (hey, at least it's stick and 4x4) |
#3 |
No, if anything adjusted to be on the slightly looser-side. I was almost ready to snug it a little, but I re-checked this morning; it turns right up to 90 degrees between water pump pulley and bank 1 sprocket, without too much effort, much harder to twist after that. I'll run it again tonight and see if the noise is still gone.
#4 |
I did the belt, pulleys, stat and w pump on my 12v a few years ago. I had a little sound too. Wasn't the belt, the aftermarket w pump stuck out another 1/16 of an inch and just barely touched the back of the fan clutch bracket. Had to pull it back off and grind a little off the back of that bracket. Was fine after that.
99.5 A4 Q 2.8 - 179,000 miles Hibiscus Red Mica |
#5 |
Thanks for the hint, I'll have a look.
#6 |
Update: After some run time, the engine now sounds normal and pretty good in my opinion for a 220,000 mile motor. Just nerves I guess, and this TB job was a warm-up for the '05 3.0 that is due next.
| Tags |
| a4, audi, belt, break, breakin, makes, noise, period, timing, whine |
