Go Back   AudiWorld Forums » Audi Models » Audi S4 / RS4 » S4 (B8 Platform) Discussion
S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-present
Old 05-06-2012, 07:56 AM   #31
FatalBert
2011 Audi S4
I assume http://www.europrice.us/amibt.jpg
doesn't work for 3g MMI? iunno.
"Bluetooth Music Interface
Finally a cordless solution to stream your digital music to your car. Cars fitted with the AMI (Music Interface) will plug this into the AMI and then you can send music via Bluetooth from your personal music player, cellular device or anything with Bluetooth capabilities. Installation instructions are included and software for your car is included on a USB drive which will setup your car for this system. Not for fitment with the 3G MMI unfortunately.
Fitment: '08+ A4, S4 (w/ AMI)
Included: Adapter - (x1), Cable - (x1), USB Drive - (x1)
Delivery: Worldwide, Inquire for Details
2011 S4 Premium Plus | MT6 | Phantom Black | Alcantara | Nav | Sports Diff | 19" 5-tri | B&O
FatalBert is offline   Reply With Quote
Old 05-07-2012, 04:53 PM   #32
FatalBert
2011 Audi S4
Does anyone know if the above will/won't work?
Old 05-07-2012, 10:51 PM   #33
sendmeone
Not sure if this helps, but I did the process exactly as Warren guy did and worked perfect. Initially I had audio issues because of the grounding but all in all it works PERFECT!
You don't need much, just your existing AMI iPod cable, a 1K ohm resistor, and the Blackberry Stero Gateway. If you purchase the gateway, all the additional cables you need come with it. What I did was use the 3.5mm cable provided and cut the USB mini adapter for the travel charger the gateway brings and soldiered both to the AMI adapter and it works amazing. I was having the same problem on my 2012 S4 with MMI 3G, if you guys like I can show you it working while it streams everything from Pandora, Spotify, Rhapsody doesn't really make a difference.
Just a little patience and soldiering skills and in about 15 mins you should have your cable.
sendmeone is offline   Reply With Quote
Old 05-08-2012, 12:47 PM   #34
sendmeone
PM me if anyone needs further help or assistance with this issue, I would be more than happy to help you guys out.
Old 05-08-2012, 09:29 PM   #35
sendmeone
** BUMP **
Old 05-09-2012, 09:19 AM   #36
sendmeone
I have received a couple of PM's asking how to open the AMI cable, here is a LINK that I used to open the AMI cable. (Go halfway down the page for pictures)
The only difference is that I did not use the CableJive option. I proceeded to solder the cables directly to the PINOUT of the AMI cable. Dug a little around the net and found these diagrams.
Audio: Pins 1,2,3,4 (I didn't use the 4 Pin on my cable, had no ground issue by just using Pin #3)
Power: Pins 25,28
Resistor Loop: Pins 21,22
Hope it helps out!
Old 05-09-2012, 06:54 PM   #37
mpatel1080
Looks like someone is selling a solution for the bluetooth streaming
http://audia2dp.weebly.com/
mpatel1080 is offline   Reply With Quote
Old 05-10-2012, 02:58 AM   #38
sendmeone
Very similar to what I did, not a bad pricing if you are not into tinkering around with a soldering gun. If you have a limited budget then all it will cost you is the Bluetooth Gateway and a little sweat.
Good find mpatel1080
Old 05-10-2012, 06:57 AM   #39
t0mt0m
2010 Audi S4
t0mt0m's Avatar
im gonna order one today, ill tell you guys how it turns out
B8 S4 '10 6MT Q | Brilliant Black | Atlas Carbon Fiber Inlays | Bang & Olufsen (7/22/10)
MODS: STRAT INTAKE | 25% TINT ALL | 034 HFCS | MILTEK RESONATED W/DOWNPIPES | THULE ROOF SNOWBOARD RACK [OFF] | JHM SHORT SHIFTER | AWE BOOST GUAGE | OEM BLK OPTICS GRILLE | APR 93 FLASH STAGE 1 V1 | APR PULLY | ALU KREUZ | KW V2 | STRAT 02 SPACERS | APR STG II V1.2 | ST STOPTECH STREET KIT | CLUTCHMASTER FX400 | KW SPNG SPCR FIX | RHO-FRONT PLATE | FORGESTAR FX14 GUNMETAL|
*RIP Amulet Red A4 '03 1.8T 5MTQ
t0mt0m is offline   Reply With Quote
Old 05-10-2012, 10:30 AM   #40
phil47
"available for pre-order"
Let us know when they think they will ship. Thanks.
phil47 is offline   Reply With Quote
2007, 2012, 3g, a2dp, a8, adaptor, audi, audia2dpweeblycom, b8, bluetooth, bo, httpaudia2dpweeblycom, input, mmi, s4, solution, sound, system, usb, vag
