Go Back   AudiWorld Forums » Technical Discussion » Motors » 12v V6 Discussion
Old 04-02-2012, 02:27 PM   #1
vtraudt
Send a message via Skype™ to vtraudt
Default Oil leak from crank position sensor
I am leaking some oil on my 1996 A4 2.8 V6 12V.
Seems to be coming from the 'crankshaft position sensor' (left side of engine. I had it out a few times during transmission change and following troubleshooting, could be the O-ring is not sealing anymore.
I want to replace the O ring. Is there a part number or generic dimensions (ID/OD/thickness) for that O-ring?
1998 Passat 1.8T manual; Kraftwerk Turbo TM2, 550cc Bosch EV14, FSI coils, 3" MAF, 3" DP, high flow manifold, S4 clutch, single mass FW, FMIC, custom TIP, Kraftwerk Tune
1999 Passat 1.8T manual; Kraftwerk Turbo TM3, 550cc Bosch EV14, FSI coils, 3" MAF, 3" DP, custom TIP, FMIC, Kraftwerk Tune
2002 Audi Allroad 2.7T quattro manual; Kraftwerk Turbo TM4, 750cc Bosch EV14, FSI coils, stg 5 clutch, FMIC
2001 Audi Allroad 2.7T quattro manual; custom stg 1
1996 Audi A4 2.8 quattro automatic. Stock. Issues: heated seats not working (from neer model), ignition lock/key hangs, TERRIBLE gas mileage.
www.regulatorfix.com
www.kraftwerkturbo.com
vtraudt is offline   Reply With Quote
1996, 27t, 96, a4, audi, check, crank, crankshaft, leak, leaking, leaky, oil, position, sensor, signs, v6
