#1 |
1994 Audi 90My Garage Join Date: Jan 2002
#2 |
Left side is noisy because you don't have oil for the hydraulic tappets so they are ticking.
What pressure valve are you talking about? Wouldn't the pcv hoses at the rear of the valve cover prevent the inside of the valve cover from being pressurized? I thought everyone left Audi World and only post on Quattroworld? |
#3 |
Some left, some are at both like I am.
The rear vent tub is not blocked, I did a very good cleaning. The valve is the one in the picture with oil dribbling out, one per side. The valve is smaller then a dime in size. From what I can tell it is a simple ball and spring, when pressure builds too much it pushes the ball up and it opens. I never knew how much sludge was in this motor until I replaced the valve cover gaskets last fall when they were leaking [original]. The engine used to be quite but not at the moment. Best course of action is to run seafoam or other cleaners to try and relieve the pressure and/or replace the valve to determine if it is not faulty. Was looking for feedback, BTDT from anybody who looked into this themselves.
#4 |
The hole with the oil oozing out is the oil hole for the CAM. Are you sure it a valve and not just a restrictor for the opening from the oil passageway?
I would look into the other side where you don't have oil oozing out as something is clogged and preventing the oil from going up into the CAM. That is why that side is making noise. Last edited by upallnight; 04-04-2012 at 05:01 AM. |
#5 |
Negative, each cam has two holes under each lobe that are oil jets, the valve in question is the pressure relief valve.
It is clearly in Bentley and it notes if a loud noise in across the bank to first check if this valve is loose and if so to replace or simply replace it. That is basically all they say. I have not found a concrete answer but simple suggestion is the valve should not be open unless pressure in that bank has exceeded what it opens at. What puzzles me is the leaking side is quiet whereas the noisy side is dry, that is the opposite of what should be happening.
#6 |
Bentley has been known to be WRONG.
On my Twincam Lotus Europa head, there is a restrictor inserted in the head to prevent a whole lot of oil from being pumped up to the head. The lifters are solid lifters so the oil is not used as in our hydraulic lifters, but oil is still need to lube the cups for the lifters and the surfaces between the cam and lifter. Last edited by upallnight; 04-04-2012 at 05:51 PM. |
#7 |
As the factory manual I highly doubt anything is wrong, known example?
Under each cam lobe are two oil ports so the lob hitting the lifter is constantly bathed in fresh oil. One just has to see a picture of a cleaned head minus the cam to see the oil ports. The valve I posted about has nothing to do with it, it is simply a check valve designed to open at a certain bar pressure. This valve will open if you added too much oil and the pressure went over spec. Probably not a common replacement but the valve could be gunked up to the point it gets stuck open when it should not be or even the opposite, baked oil blocking the entry not allowing it to open up. When the weather breaks I will look into this further.
#8 | |
Bentley also provides manuals for BMW and Porsche cars. As a former BMW owner I am/was on BMW forums. The ohm reading for the CPS for E34 BMW are wrong, and the Ohm readings for testing the coil packs are also incorrect. I haven't need to do a lot of trouble shooting on my Avant so I haven't need to use Bentley that often. I'm sure if you do a search you will find errors in the Bentley Manual for our cars. Here's a quick review on the Bentley Manual by Audi owners. http://www.audiforums.com/forum/audi...manual-124193/ If you can't tell the left side from the right side I think that is an error. LOL Last edited by upallnight; 04-05-2012 at 04:59 AM. |
#9 |
i think you have this mixed up. There not relief valves, they are oil retention valves. They keep oil in the top end of the engine for lubricated start ups. If Bentley is calling them relief valves, they are wrong, which is isn't uncommon for those manuals to have errors all over.
1992 Audi 100 CS Quattro 1990 Audi 200 Avant Turbo Quattro 1991 Audi 200 Turbo 1999 Audi A6 Avant |
#10 |
Per ETKA, they are called "pressure limiting valves", P/N 078–103–363–P, one in each head (AFC engine). There are also the (2) "check valves" underneath the intake manifold in the valley.
| Tags |
| 1994, 2001, 2007, a6, allroad, audi, b6, lifter, oil, pressure, prv, release, relief, valve, valves |
