| S4 / RS4 (B5 Platform) Discussion Discussion forum for the B5 Audi S4 & RS4 produced from 1998-2002 |
#1 | ||
#2 |
on my new 01 TT 225Q i have yet to see any fan run, the afterrun coolant pump comes on, thats it. i replaced coolant sensor with a green top, temps have only reached about 70 since purchase in dec 11, temp guage starts at a quarter and goes to 5/8, summers comming we will see i guess, sure does not seem right
#3 | |
2012 Audi Q5My Garage Join Date: Mar 2005
#4 | |
#5 |
I tested the passenger side fan and it's dead. I got a replacement and plugged it in, but it didn't kick on. When exactly should this fan kick on? My other electric fan (driver side) runs with the AC. Is the passenger side one just the after-run fan if the engine is too hot? Also, I looked at the timing belt DIY to see the service position. Do you need to get the car in full service position to replace that fan, or is there a point where you can just slide the front forward a few inches and replace it that way?
#6 | |
#7 |
1951 Dodge WayfarerMy Garage Join Date: Apr 2008
Probably needs new brushes for the fan motor, I just did them on my 2000 S4. Quite hard to find. I found most Audi fans from 90s up are basically the same PN with different suffix. The brushes are mostly the same so you can get a fan motor from a salvage yard that runs and swap the brushes if the fan configuration isn't exactly the same.
#8 |
Thanks for the updates guys. Turns out it was just a bad fan, picked up a replacement from the classifieds and installed. It didn't kick on on my original test. I tested it again and after a minute or so of the car and AC running, it kicked-on. Still not certain what conditions cause this fan to operate, but it seems to be working.
#9 |
a scan by a knowlegable VCDS operator can determine most issues, i stopped in my favorite tuner shop APTuning Lebanon PA, for about $50 i had my answer, a bad relay, fans only ran on lo speed, its better than throwing parts at it, sometimes you are lucky but electrical stuff is usually not returnable so a simple diagnostic is worth it, stealers will kill you, find an honest independent shop
| Tags |
| allroad, audi, audiworld, bridging, control, coolant, fan, fc, fuse, j293, location, module, pump, replace, run, s4 |
