| A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5-present |
#1 | ||
#2 |
2013 Audi A6Join Date: Jul 2001
Could be one of these (been there on all of these at some point in my life):
A rear tire wasn't balanced properly, defective tire, bent wheel, lug nut(s) not torqued correctly, drive train or rear suspension issue or chassis or axle bolt loose; doesn't sound like an engine issue. Most likely one of the first three.
![]() - 2013 A6 3.0t Prestige, Quartz Gray/Black, 19" Sport, Driver Assist, LED headlights,Cold Weather and B&O; Bridgestone RE970AS tires; X-Pel Ultimate full front, mirrors and rocker panels - 2009 A4 3.2 Prestige w/Nav (sold at 48K mi) - 2002 allroad 2.7t - 48K mi after 12 years (and still like new) - 2001 A6 2.7t (sold at 98K mi) |
#3 |
Thought I would leave a follow up post on what the issue was. Eventually I ended up getting a CEL that indicated a misfire in cylinder 2. which turned out to be a bad injector. The dealer replaced all 4 while in there (still under warrenty) but seemed as if it was only the one. The dealer thinks it was probably defective. This also fixed the vibration issue. I noticed the vibrations before as I noted in my original post but did not realize how poorly the engine had been running in general. Guess it degraded slowly. With the new injectors there is a big difference in performance, especially starting from a stop.
#4 |
Glad you got it sorted, and also under warranty. I'm no expert, but I believe a VagCom scan would have noted the misfires, even though it didn't set a CEL initially.
Jim 2011 A4 Avant |
#5 |
I did run a scan before the CEL and did not show the misfire
#6 |
The frequency of injector problems seems to be non-trivial enough to be noticed.
#7 |
the fuel injector issue does seem to be a frequent issue.
See thread "EPC and CEL + power loss and shake". http://forums.audiworld.com/showthread.php?t=2822230
Current: 2010 A4 Avant S Line, Driver Assist Quartz Gray/Black 2006 Range Rover HSE Black/Gray Previously Owned: 2003 Audi A4 Cabriolet 3.0 Black/Black |
#8 |
I wonder whether there is something inherent to the injectors or whether the failures are caused by peripheral components such as a bad fuel filtering system, bad pressure regulator, etc. The failures could even be caused by fuel lines or fuel tanks degrading and dumping tiny particles into the fuel that damage the injectors. |
| Tags |
| 03, 06, 2012, a4, a6, accelerating, acceleration, audi, bad, change, epc, recent, shaking, tire, vibrate, vibration |
