Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B7 Platform) Discussion
Old 03-15-2012, 06:47 PM   #1
keithandstef
Default Strange oil leaks on top of engine
Please forgive me, as I don't know what these little torx bolts hold down, but there is some oil leaking out of two of them. You can see in the picture that one (on right) is dry, and the two left ones are cleaned up now but had oil slightly pooled around the torx bolts. What gives please? Thanks in advance for any help.
keithandstef is offline   Reply With Quote
Old 03-15-2012, 07:35 PM   #2
keithandstef
This is a 2007 A4 Quattro S-line (manual) by the way, if that makes any difference, with 55K miles
Coilpack failure?
Valve cover gasket?
Perhaps unrelated is the car died upon start-up yesterday after I had driven a bit and parked it. I started her, then it died. Did it again and died again. Third time I got her to fire up and gunned it to get when might be a some bad gas in my mind through the chamber. been fine ever since. No acceleration or idle issues. But I did notice the small leaks today.
Old 03-15-2012, 07:44 PM   #3
UrQuattroKid
1993 Audi S4
UrQuattroKid's Avatar
Originally Posted by keithandstef View Post
Coilpack failure?
Valve cover gasket?
I was thinking the same suspects but also the oil filler cap's gasket could be weeping some oil. But really not much oil leaking so I would wipe it off and look at it after every drive you do to try to get a better idea where its coming from :P
UrQuattroKid is offline   Reply With Quote
Old 03-16-2012, 04:18 AM   #4
rdA4WtQ5
Re-torque those torx screws. Don't over tighten. You may have to re-do a few times over a few weeks then it will be good. The wetter ones will be the most loose each time.
2011 Q5 Ibis White 2.0T
2008 A4 Cabriolet Ibis White 2.0TQS
2000 A4 Laser Red 1.8TQM (sold)
rdA4WtQ5 is online now   Reply With Quote
Old 03-16-2012, 05:36 AM   #5
UrQuattroKid
1993 Audi S4
they don't even go through the valve cover or into anywhere there is oil......something else is leaking
Old 03-16-2012, 07:28 AM   #6
keithandstef
Taking it in next week for some routine maintenance, and mentioned to the guy on the phone the issues. There are several recalls out there he says, and one may adress this. We will see, and I'll provide an update.
Old 03-16-2012, 10:45 AM   #7
kierantaylor
I had same issue (under warranty) and they said it was a TSB and that they replaced a gasket
HTH
kieran
kierantaylor is offline   Reply With Quote
Old 03-16-2012, 02:25 PM   #8
keithandstef
HTH
kieran
Valve cover gasket? Thanks.
Old 03-18-2012, 05:19 AM   #9
91c2wrencher
91c2wrencher's Avatar
Might be that the PCV valve(or I think audi calls it a PRV valve) has failed? pretty common on this vintage car. Happened to me,and I had oil around the filler cap that dribbles down into those torx bolt holes and looks like real trouble, do a search on this and be sure to pay attention to hose updates as well. I did mine myself and it was easy. FWIW, shortly after the repair while in the dealer for routine maintance the service manager noticed the remnants of the oil in the holes and tried to convince me I needed a new head gasket!!!! mentioned to him the recent repair on the PRV valve and he backed right off.
91c2wrencher is offline   Reply With Quote
Old 03-18-2012, 07:18 PM   #10
keithandstef
You guys may be onto something here. Last oil change (at Audi), they didn't tighten down my oil cap. Nice. This may be just left over dribble that I only now noticed. I've cleaned it up and haven't noticed any more. although it's odd it bypassed the first spot, and actually made it to the third. How did it get past the coil pack? Who knows. But will mention the PCV valve for sure this Thursday when it goes to the shop. Thanks.
17d9, 1993, 2008, a4, audi, engine, gas, leack, leak, leaking, oil, pcv, rvu, s4, top, update
