#1 | ||
#2 |
If you have the means you should do it. Where are you? Someone might be able to lend you the special tools required.
1994 Audi Cabriolet (now with 5 speed!) 1994 Audi Cabriolet - the really really crappy one 1995.5 Audi S6 1993 Audi 90 CS Quattro (sold) |
#3 |
if it breaks you could have a fubar engine.
I would replace the T-belt W-Pump T-Stat All rollers Acc belt Acc belt tentioner Cam seals Crank seal All is accessible when you do a timing belt...standard for when I buy a 12v
"Spartans never die" Spartan 051 - Kurt Status:MIA |
#4 |
Boy that is a long time. But I wouldnt fear it for a 1400 mile drive. I have seen V6 Audi cars go 150k before they finally break the belt. While the 1.8T cars somtimes break at 85k lol. I would just drive it on your trip and then do a timing belt and the whole bit when you have time.
1992 Audi 100 CS Quattro 1991 Audi 200 Turbo 1999 Audi A6 Avant 1998 Audi A4 quattro |
#5 |
Thanks for the information. I will not have time to do any work myself. I am flying to pick the car up and drive it back. I think I will go ahead and get it done. It will need done some time and better to be safe than sorry. Guess I just wanted to make sure I wasn't being overly cautious. I usually buy new and sell them long before any major service is due. This is my first try at a used car that I want to maintain and keep. Thanks! Great forum!
#6 |
1993 Audi 90My Garage Join Date: Oct 2008
im with Luxus on this, IIRC, the life expectancy of a t-belt is 80k or 5 years, which ever comes first
1993 Audi 90CS Quattro (loving it) *new front struts, 034 control arm bushings, tie rods. mount savers. B5 sport rear springs/socks, B5 sport swaybar, B5 upper a-arms, 034street density trans mounts,17" ASA, head lights, aux gauges. blue plasma instrument cluster, A4 3 spoke steering wheel, aluminum subframe mounts) *replaced a motor at the end of 2008, gasket matched heads, ARP head studs, air box velocity stack, 4 to 3 wire MAF conversion, 18.5lbs flywheel with SPEC stage 2 clutch. 1975 VW bus (gone) 1973 VW Super Beetle (what was i thinking?) 1968 VW Bug (my pride and joy) *2.5 inch front drop and disk brake conversion, *2110cc motor (in progress)new wiring harness,3 inch wider fenders all around, 195/45r15 front and 195/65r15 rear tiers 1991 GMC Sonoma RWD, manual, 4 banger (gone) 1979 Suzuki GS750EN with 31k original miles 1981 Suzuki GS750L (will be on a chopping block for a bobber) 1981 Yamaha XV920 1983 Yamaha XV750 (for g.f.) 1985 Dnepr MT10-36 (stolen) 1992 Dnepr MT11-32 (also stolen) |
| Tags |
| 42, a6, audi, belt, replace, replaced, timing |
