#11 | ||
1998 Passat 1.8T manual; Kraftwerk Turbo TM2, 550cc Bosch EV14, FSI coils, 3" MAF, 3" DP, high flow manifold, S4 clutch, single mass FW, FMIC, custom TIP, Kraftwerk Tune 1999 Passat 1.8T manual; Kraftwerk Turbo TM3, 550cc Bosch EV14, FSI coils, 3" MAF, 3" DP, custom TIP, FMIC, Kraftwerk Tune 2002 Audi Allroad 2.7T quattro manual; Kraftwerk Turbo TM4, 750cc Bosch EV14, FSI coils, stg 5 clutch, FMIC 2001 Audi Allroad 2.7T quattro manual; custom stg 1 1996 Audi A4 2.8 quattro automatic. Stock. Issues: heated seats not working (from neer model), ignition lock/key hangs, TERRIBLE gas mileage. www.regulatorfix.com www.kraftwerkturbo.com |
#12 |
Does the 2.8 have EGT sensors that could go bad and tellung the ECU to run rich to 'cool', causing the high gas consumption?
#13 |
pull the injectors out, but leave them attatched to the fuel line and rail, and turn the key on so the fuel pump primes. but dont start! and put paper towels under each injector, and any that get wet, are leaky and bad. also you can use an ohm meter, and check the resistance of each injector. They can electrically short out.
Bosch injectors - 15-17 ohms Siemens injector - 13.5-14.5 ohms Anything dramatically less is junk.
1992 Audi 100 CS Quattro 1990 Audi 200 Avant Turbo Quattro 1991 Audi 200 Turbo 1999 Audi A6 Avant |
#14 | |
Will do.
Get a set of O-rings (number/specification to order the correct ones? Source?) and change them out while at it? Quote:
#15 |
would the injectors make the check engine light come on if bad. got the same white slim on oil cap and in breather hoses. my check engine light will come on if it sits and idles for 10-15 mins. car also wants to die right after starting will rum real rough at around 3-4 hundred rpm for about 5 mins then it seems to come out of it. Then at low rpm wile driving it hesitates. at about 2000 rpm it seems to come out of it but still dont feel like it has full power. and what would symptoms of one clogged cat and the other free flowing. exhaust makes weird high pitched kackle. caused by misfire? or what
#16 | |
I have 2.5" exaust from right behind the cats into a cherry bomb glass pack for resinator then into a pilot dual 3" tipped muffler
| Tags |
| 18, 2002, 30, a6, audi, clean, code, fuel, hose, mpg1, pcv, pressure, regulator, slime, valve, vent, white |
