Go Back   AudiWorld Forums » Audi Models » Other Audi » Audi 100 / A6 (C4 Platform) Discussion
Old 03-13-2012, 11:51 AM   #11
alikat
I will have it done tonight and will post the results. THANK YOU..
alikat is offline   Reply With Quote
Old 03-13-2012, 09:12 PM   #12
alikat
As it was explained WTF are the fuses??? He removed the passenger side
kick plate and there is a mess of connections but??? FUSES?? WTF AGAIN
as he says.. lolol He went and had a beer.. probably a few..
Old 03-14-2012, 04:50 PM   #13
Prospeeder
Open the drivers door. See on the end of the dash the little cut out, pry it off. There they are. There is also a aux fuse and relay panel under the hood in the drivers side corner which is where engine managment fuses are usually.
1992 Audi 100 CS Quattro
1991 Audi 200 Turbo
1999 Audi A6 Avant
1998 Audi A4 quattro
Prospeeder is offline   Reply With Quote
Old 03-14-2012, 06:22 PM   #14
alikat
OK.. Found it, under the carpet on the passenger side.
All fuses S72 etc on the bar are good.
Codes read
P1106 02 sensor bank 2 low voltage
P1250 Low level fuel (Has 1/2 tank)
P0156 02 sensor bank 2 malfunction
Old 03-14-2012, 06:23 PM   #15
alikat
Missed typing in
P0401 EGR Flow insufficient
Old 03-15-2012, 06:40 AM   #16
audiqv8
None of these code should prevent your engine from starting. Perhaps you flooded the engine. Remove a spark plug and see if the plugs are wet. You already stated that you have spark.
Here is how you test injectors, watch the video until the end.
http://www.youtube.com/watch?v=-KCAA9G2s0U
audiqv8 is offline   Reply With Quote
Old 03-15-2012, 01:37 PM   #17
alikat
Great video, learned a lot in a short time.. I will get it checked
tonight and post later today.
Old 03-15-2012, 01:38 PM   #18
alikat
With that car sitting for a few days, it would still be flooded
to not start?
Old 03-17-2012, 01:00 PM   #19
alikat
The 2 plugs we checked where bone dry, put an led to check to see if the
injectors are firing and they are not, checked the spark off of the wire
and it is working. I assume that the crank sensor helps the electrical
circuit (electrical spark) but what works in conjunction to turn on the
injector on?
Old 03-18-2012, 06:14 AM   #20
audiqv8
Check to see if there is power to the fuel injector. One side should be hot (+ white/green wire) and the ground (-) is supplied by the ECU. Fuse S72 should be positive side. (See previous posted electrical diagram). If there is power on one side of the injector then the ECU is not supplying the ground needed to complete the circuit and fire the injector. LED have a positive and a negative side so if it doesn't light/flash, try flipping the wiring around. The cam signal is needed by the ECU in order to provide the ground to the injector. What type of code reader are you using?
17514, audi, code, p1106
