Go Back   AudiWorld Forums » Audi Models » Other Audi » Audi 100 / A6 (C4 Platform) Discussion
Old 03-29-2012, 05:22 AM   #21
audiqv8
Originally Posted by sugaryling View Post
Camshaft alignment tool arrived and guess what? It doesnt fit! It's the correct width apart (unlike my 2.7T, it's wider) from cam to cam but the damn pins that goes into the cams are opposite. The small pin is lined up with the large hole and vice versa.
You might have to rotate the crankshaft another 360 degree. Remember the crankshaft have to rotate 720 degree for the cam shaft to rotate 360 degree.
audiqv8 is offline   Reply With Quote
Old 03-29-2012, 06:20 PM   #22
Prospeeder
beat me to it. Cams spin at half the speed of the crankshaft. So by that, you would have to turn the crankshaft 2 times for the cams to turn once. so yes. turn the engine another revolution
1992 Audi 100 CS Quattro
1990 Audi 200 Avant Turbo Quattro
1991 Audi 200 Turbo
1999 Audi A6 Avant
Prospeeder is offline   Reply With Quote
Old 03-30-2012, 06:40 AM   #23
sugaryling
DOH!!! YOU ARE TOTALLY RIGHT!!! I've done this many times with my 2.7 and it does need another rotation to get the larger holes to line up on the opposite side. I'm such a fool! The C4 is all new to me so I guess it just slipped my mind. Thanks for the reminder.
sugaryling is offline   Reply With Quote
Old 03-30-2012, 06:50 AM   #24
sugaryling
Originally Posted by upallnight View Post
Unless you are replacing the timing belt, you could have replaced the thermostat without having to buy the cam alignment tool. It's a little bit harder with the timing belt still in place, but doable. You will also need the crank pin if you going to use the cam tool.
Really? I'll give it a shot. Although I just received the cam alignment tool in the mail. I've replaced a number of TB on the 2.7 with out the crack locking pin tool and it's fine. I don't think the crank lock tool is really necessary, just insurance I guess.
Old 04-16-2012, 11:51 AM   #25
dubblrest1985
are your cooling fans turning on?
dubblrest1985 is offline   Reply With Quote
Old 04-16-2012, 07:07 PM   #26
sugaryling
They are not! This was the problem all along! See my other post about fans not coming on.
100, 100cs, 1992, 2000, 94, audi, blown, bottle, builds, expansion, heats, overheating, pressure, resevor, s4, tank, urs4
