#11 | ||
2012 Audi Q5My Garage Join Date: Mar 2005
#12 |
spewing from the expansion bottle means the engine is building up too much pressure in the cooling system. Your car is overheating which is causing the water to boil and turn to steam. You either have a bad thermostat, bad water pump or a clogged radiator. If the radiator is cold you have a bad thermostat, if the radiator is hot in one section but cool or cold in another section you have a clogged radiator. If the radiator is warm or hot throughout you have a bad water pump.
#13 |
I did flush the radiator form the top and water runs out the bottom hose just fine. Sure doesn't seem clogged.
#14 |
That won't tell you anything, that's why I said, you have to know all the components are fine. You usually have to feel or check the radiator with a temp gun when its overheating to know if it's cooling properly. Several cores can be blocked and the water will run through it fine with a hose, but it's running through the unclogged sections of the radiator core, not the entire radiator.
#15 |
Gotcha! Well I don't have one of those temp guns. Maybe I'l get one from Harbor freight this weekend.
The cam alignment tool just arrived. I'm going to replace the thermostat in the next few days. I've been driving for the past 4 days and the car hast over heat yet. This kind of makes me think that it's not the radiator or else it would over heat more often. What do you think? |
#16 | |
#17 |
If you cannot find any other leak, go with a cap first (I think dealer is 30 bucks).In the meantime, if you are in tough driving conditions, put the heat on high. Try to see which happens first, temp gauge or steam from the engine.
#18 |
Unless you are replacing the timing belt, you could have replaced the thermostat without having to buy the cam alignment tool. It's a little bit harder with the timing belt still in place, but doable. You will also need the crank pin if you going to use the cam tool.
#19 |
Camshaft alignment tool arrived and guess what? It doesnt fit! It's the correct width apart (unlike my 2.7T, it's wider) from cam to cam but the damn pins that goes into the cams are opposite. The small pin is lined up with the large hole and vice versa.
#20 | |
I replaced the cap today. Less than $2 for a Meyle one. Now when the temp gauge overheats, I pop the hood to check and steam and is hissing from under the coolant tank and rising up and around it. I think I'm going to replace the coolant tank next and see what happens. Before I replaced the cap, when I pop the hood, I would find coolant spewing from the side of the cap. New cap, no more spewing. I'll try my best to monitor the temp gauge vs. steam from the hood. Last edited by sugaryling; 03-28-2012 at 08:21 PM. |
| Tags |
| 100, 100cs, 1992, 2000, 94, audi, blown, bottle, builds, expansion, heats, overheating, pressure, resevor, s4, tank, urs4 |
