#1 | ||
2002 Audi A4 |
#2 |
you dont need to take the whole front end off. Which model is it. A4 or A6?? Basicly there are T-25 screws holding the fender liner, take them out so you can reach your arm in the bumper, fine 3 10mm nuts each side holding the bumper cover to the fender. Pull off the 2 fog light grills, straight up each side is 1 8mm hex bolt that's really long, pull it out. Carefully give a controlled quick jerk and the bumper cover will pull off. Don't pull it to far yet, there's a fragile connector for the headlight washers you need to disconnect, and 4 electrical connectors, 2 for fog lights, 2 for horn. Now, you will see 6 T-30 bolts holding the carrier to the fenders. You will then notice 4 on one side and 3 on the other side T-45 bolts. Take 1 on each side out, put a stud of the same thread but very long in each, then remove the rest of the T-45 bolts. Now pull the entire carrier 6-8 inches forward. That's service position, you can do Timing belt ect easily now.
If your just replacing the drive belt, a skilled person can do it without putting it in service position.
1992 Audi 100 CS Quattro 1990 Audi 200 Avant Turbo Quattro 1991 Audi 200 Turbo 1999 Audi A6 Avant |
#3 | |
2002 Audi A4 |
Ok thank you!! My buddy and I are going to attempt the "skilled person" position today and see what we can do.. If that doesn't go well we will do the service position.. Thank you for all the measurements!! And btw, it's a a4
| Tags |
| 100, audi, audiworld, diy |
