Go Back   AudiWorld Forums » Technical Discussion » Motors » 2.7T V6 Discussion
Old 03-01-2012, 11:24 AM   #1
jonah
Default WTB: m box ECU. Pref. APR or GIAC. (Car down again, ecu died second time in 2 years.)
Also: what might be causing it to fail?
S4 - "A Wolf in Sheep's Clothing"
[Get your PhatBox install info here]
jonah is offline   Reply With Quote
Old 03-01-2012, 12:21 PM   #2
Prospeeder
Well, im certain you would have codes. BUT i have seen several times that shorted o2 sensor heater elements or shorted o2 heater wiring causes ecu failure. For some seriously flawed reason the heater wires go directly to the ecu.... The ecu is located in the plenum chamber? The seal in the connector is gone, too much moisture getting in. Not bolted in or secured correctly so its bouncing around causing damage. or just poor quality replacments.
1992 Audi 100 CS Quattro
1990 Audi 200 Avant Turbo Quattro
1991 Audi 200 Turbo
1999 Audi A6 Avant
Prospeeder is offline   Reply With Quote
100cs, audi, box, ecu, quattro
HTML code is Off
