Go Back   AudiWorld Forums » Technical Discussion » Electronics » VAG-COM Discussion
Old 02-22-2012, 12:58 PM   #1
Ice_Coffee
Default Audi A4/RS4 Bi Xenon to Bi Xenon with AFS retrofit
First off, hello everyone this is my first time posting on this forum.
I have been busy retrofitting my AFS headlights into my RS4 so far it has gone quite well, I managed to scour information from the internet and the Elsawin current flow diagrams to get a pin out of the 26 pin connector for the old headlight control module (8P0 907 357)and the new replacement module(4F0 907 357E).
After AFAIK correctly modifying the T26 connector, I am now in a situation where I have comms to the lights, they do the power on test ie UP, Down, Outer limits, Inner Limits and using VCDS I can manually push them Up down etc etc.
However I have a fault
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
I have checked the internet, and attempted to do a basic setup of the lights, which resulted in an error.
I have then tried to interrogate my level sensors but im not really sure what im looking for, which has brought me here.
Wednesday,22,February,2012,15:20:24:18686
VCDS Version: Release 11.11.2
Data version: 20120126
Chassis Type: 8H - Audi Cabrio B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 26 36 37 45 46 55 56 57 63
65 67 73 75 76 77
VIN: NOT Disclosed Mileage: 66210km/41140miles
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI Ş0090
Revision: 57H13--- Serial number:
Coding: 010C0003180F0160
Shop #: WSC 00370 210 91461
VCID: E3CFDDA4224E19B
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Revision: 00000000 Serial number: 00000000000000
Coding: 0004533
Shop #: WSC 00672 785 00200
VCID: 2B5FF5848A1E11B
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2833
Coding: 00100
Shop #: WSC 00672
VCID: 6DDB3B9C278ADFB
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 21021
Shop #: WSC 00000
VCID: 3D7BCBDC376A8FB
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
Address 15: Airbags Labels: 8H0-959-655-94.lbl
Part No SW: 8H0 959 655 E HW: 8H0 959 655 E
Component: Airbag 9.42 H09 1840
Revision: 92H09184 Serial number: 0037Y000F9J1
Coding: 0471114
VCID: 3C7DC6D87F70863
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0201
Coding: 06021
Shop #: WSC 00672
VCID: 448DBE385480FE3
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8H0 920 981 G HW: 8H0 920 981 G
Component: KOMBI+WFS 4 H14 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0021411
Shop #: WSC 00370 210 999999
VCID: 346DEEF854204E3
Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255 A
Component: VSG B6 CABRIO 6894
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8H0 035 192 F HW: 8H0 035 192 F
Component: RNS-E HIGH EU H72 0550
Revision: 01S Serial number: AUZBZ7F1255194
Coding: 0419114
Shop #: WSC 00672 785 00000
VCID: 2A51F08086E4083
1 Fault Found:
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 58
Time Indication: 0
Date: 2012.02.19
Time: 10:04:28
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8H0 951 178
Component: Innenraumueberw. 0411
Coding: 00001
Shop #: WSC 00000
VCID: EFE7A194AD86ADB
1 Fault Found:
01350 - Alarm via Theft Warning System; Rear
43-00 - Closed
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8H0 959 433 K
Component: Komfortgerát T3B 5141
Coding: 07915
Shop #: WSC 00672
VCID: 3C7DC6D82C70863
Subsystem 1 - Part No: 8H2959802D
Component: Tőrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8H2959801D
Component: Tőrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8H0959801A
Component: Tőrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8H0959802A
Component: Tőrsteuer.HR BRM 0002
1 Fault Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000019
Shop #: WSC 06335 000 00000
VCID: 28550A889BE83A3
Part No: 8E0 941 329
Component: AFS-Modul links H03 0020
Component: AFS-Modul rechtsH03 0020
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
02234 - Right Headlight Power Output Stage (J668)
014 - Defective - MIL ON
Freeze Frame:
Fault Status: 11101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0419114
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 58
Time Indication: 0
Date: 2012.02.19
Time: 10:04:28
Address 63: Entry Assist,D Labels: None
Part No: 8H0 959 760 A
Component: EasyEntry F H13 0010
Coding: 32767
Shop #: WSC 131071
VCID: 356BD3FC0F5A57B
1 Fault Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0022825
Address 73: Entry Assist, P Labels: None
Component: EasyEntry BF H13 0010
Coding: 00005
Shop #: WSC 00065
1 Fault Found:
01733 - Switch for Head-Rest Adj. Pass. Seat (E170); Down
28-10 - Short to Plus - Intermittent
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 E HW: 8E0 919 283 E
Component: Parkhilfe 8-Kan H06 0010
Revision: 00H06000 Serial number: 00067802120614
Coding: 0000124
VCID: 3261E8E0AE34403
End ---------------------------------------------------------------------
Ice_Coffee is offline   Reply With Quote
Old 02-22-2012, 01:02 PM   #2
Ice_Coffee
I also took this screen shot of relevant level sensor info
Old 02-22-2012, 01:18 PM   #3
Ice_Coffee
Also, is there anything else other than the head lights themselves connected to the interior wiring harness Can Bus ?
I only ask, as the old module was connected to the dash panel can bus only, but the new module is connected to both the Dash panel can bus and the interior wiring harness can bus.
In my current wiring setup it has working direct comms with both headlights via this link.
Old 03-10-2012, 09:24 AM   #4
Ice_Coffee
Default How to do it ;)
There are plenty of threads on the internet showing how to retrofit bixenons or even bixenons with AFS, to an A4 B7 with Halogens (usually with the help of loom adapters from kufatec) however there is very little information on how to convert BiXenons to BiXenons with AFS. I have successfully managed to do this conversion so I am making this post as a guide.
First off big thanks to the A6 wiki, which actually had most of the information I needed but I did not believe it, as I was thinking how could Audi change so much of the system just to add cornering function.
A6 Wiki here http://a6-wiki.de/index.php/Nachr%C3%BCsten
Big thanks to Google as I use chrome browser which auto translated the A6 wiki into English for me. I would have gotten nowhere if that language barrier had not been removed.
Big thanks to "Ghosting" a member of a German forum where they talk about Motors as he also had useful information that helped this happen.
Finally a BIG thanks to Dana at ross tech who spotted some coding of a module that I had missed.
You will need
A matching pair of cornering headlights, in the UK you can purchase them new (and cheap) from the link below this paragraph, but I dont think the new ones come with any control ballast/ignitor or bulbs
http://www.allpartssouthwest.com/aca...k5_06_06_.html
You will also need
a 4F0 907 357 afaik C,D,E,F headlight control computer from an audi a6 but I strongly recommend an E or F variant, the B7 A4's would have come with E as standard just because of the years they were manufactured.
F was the last variant (before the major change to the 4L0 907 357) and came with software to better cope with an issue on the headlight controller that results in 1 or both headlights flickering especially when older/ several hours of use. All Variants from B onwards can be firmware updated at the dealers to the latest firmware 4F0 910 357F
You will also need VCDS/Vagcom and the appropriate cable
as well as the necessary skills for joining wires.
Fitting the headlights is a straight swap.
Fitting the new control module requires some re-wiring of the 26 pin connector that plugs into it.
Remove your glovebox
Behind the glovebox (affixed to the roof of the cavity) is the old headlight controller 8P0 907 357, which I think is actually from an Audi A3, but don't quote me on that.
the following is the pin outs for the 2 controllers
Headlight for gaseous discharge light (Xenon plus) and automatic headlight range control
from November 2005
8P0 907 357 Pin connections
1 Not Used/ Pin nonexistent on AFS/Headlight control Module
2 Connection (high bus), in dash panel wiring harness
3 Connection (low bus), in dash panel wiring harness
4 Not Used
5 Not Used
6 Front Level Sender (6/s) connection
7 Rear Level Sender (6/s) connection
8 Not Used
9 Not Used
10 Rear Level Sender (5/+) connection
11 Rear Level Sender (1/-) connection
12 Front Level Sender (1/-) connection
13 Not Used/ Pin nonexistent on AFS/Headlight control Module
14 Not Used/ Pin nonexistent on AFS/Headlight control Module
15 Right headlight range control motor, Pin 1 in connector at headlight
16 Left headlight range control motor, Pin 3 in connector at headlight
17 Left headlight range control motor, Pin 1 in connector at headlight
18 Left headlight range control motor, Pin 4 in connector at headlight
19 Left headlight range control motor, Pin 2 in connector at headlight
20 Right headlight range control motor, Pin 4 in connector at headlight
21 Right headlight range control motor, Pin 2 in connector at headlight
22 Right headlight range control motor, Pin 3 in connector at headlight
23 +(ive)
24 GND
25 Front Level Sender (5/+) connection
26 Not Used/ Pin nonexistent on AFS/Headlight control Module
Headlight for gaseous discharge light (Xenon, plus), dynamic cornering lights and automatic headlight range control
from November 2005
Pin connections
4 Not Used
5 Not Used
6 Not Used
7 Not Used
8 Not Used
9 Not Used
10 Rear Level Sender (1/-) connection
11 Front Level Sender (1/-) connection
12 Rear Level Sender (5/+) connection
15 Not Used
16 Not Used
17 Not Used
18 Connection (high bus), in interior wiring harness. Pin 1 from both headlights (ie the wires that went to Pin 17 & 15) come here
19 Connection (Low bus), in interior wiring harness. Pin 2 from both headlights (ie the wires that went to Pin 19 & 21) come here
20 Not Used
21 Front Level Sender (6/s) connection
22 Rear Level Sender (6/s) connection
23 +(ive)
24 GND
In short you need to do the following with the wires
PS you need to remove the outer cover from the 26 pin connector there is a gate at one end that slides up you can then remove the black insert. You can use a point to undo the locking clasp for each pin in the connector (only undo the pin/s you are currently working with).
Level Sensors
PIN:
6 moves to 21
12 moves to 11
11 moves to 10
10 moves to 12
7 moves to 22
To my colour blind eyes they all look nearly the same colour, so I recommend labelling them before you start.
Power for the headlight range and cornering motors.
Remove the current wire for pin 18 and pin 20 join/solder them, they then need to be fed 12V+ from terminal 15 on the fuse block. this is the exact same place that pin 23 is currently getting it`s power from.
Data Comms to the Cornering headlights
pin
15 is Joined/Soldered to 17
new wire combination 15&17 moves to 18
19 stays where it is but pin 21 is Joined/Soldered to it
the wires currently going to pin 16 and pin 23 can be removed from the connector, they are no longer necessary.
If your 4f0 907 357 has actually come from an a6 not an a4 it will need to be logged into at address 55 and recoded as 00019 which is an a4
you will need to log into the computer at address 17 adaptation 60 and tell it you have curved lights. Thanks Dana
The cover that went over the black insert for the 26 pin connector can no longer be used, either purchase the correct one for a 4fo 907 357 from audi or plug the black connector into the pins. BE WARNED that pin 1 and 14 (also 13 and 26) are non existant on the control module YOU MUST line pin 2 (and 15) of the black connector up with the first available pair of pins on the control module.
If all goes well the only fault you should have with computer 55 (your 4f0 907 357)is
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
this essentially means your auto leveling sensors are not calibrated
you can do it yourself badly on some flat ground, the instructions are on the internet but I recommend letting somebody with the proper headlight height adjust equipment do it for you.
IF YOU HAVE ANY OTHER FAULTS ON COMPUTER 55 THEY MUST BE REMEDIED FIRST OR IT WILL NOT LET YOU CALIBRATE YOUR LEVEL SENSORS AND AFS AND AUTO LEVELING WILL NOT ACTIVATE, but you will be able to make your headlights move (to test functionality) using VCDS.
I shouted that last bit because I ignored the " Right headlight power output stage" fault thinking it was unimportant as my headlights worked perfectly, I then spent ages checking and rechecking my wiring to try and find out why it would not let me calibrate my level sensors. It turns out my wiring was perfect and I just had a faulty right headlight ballast/ignitor.
4f0, 4fo, 760, 8h0, 907357, 959, a4, afs, audi, b6, bi, coding, maudiworld, retrofit, xenon, xenons
HTML code is Off
