| Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2 |
#1 | ||
#2 |
![]() Join Date: Feb 2001
Run, Forest, Run. Your mechanic is trying to rape you. $1200. LOL. Yikes. He doesn't know anything about UrS-cars and is trying to rip you off.
Try MRC through Chips-Ur-S.com or Intended Acceleration or even 034. Hey, you are in Colorado, go to Steve Eiche in Arvada (Shadetree Software). Around $500 including a VMAP (3.0 Bar MAP) sensor so you will be Stage 1+ (around 270-280 hp).
Naturally, IMHHEO(tm), Dave F. aka the Librarian Car and Mods: 93 S4, 1.8t coil pack conversion (First in world using integral POS coil packs (??)), CF (OE), S6 steering wheel, RS2'd, Samcos, MRC, TDS-1, Apikol FMIC, Eibach/Bilstein, BIRA Sys 1, relayed FP Click here to link to the UrS FAQ Thread Start Uncle Dave says "You want my 'high horse, elitist' opinion ?(IMHHEO(tm))Then just post something stupid." Unofficial Chief Cat-herder Vancouver UrS-car club Last edited by UrS4boy; 02-16-2012 at 07:33 AM. |
#3 |
Wow. That quote came from Auto Sport Works in Broomfield around $1200. Are they not the best folks my car?
I will visit with your suggestions locally
#4 |
I will second the suggestion that you use Alex at Intended Acceleration. I have Alex's Stage 3+ ECU with the 3 bar sensor update and am running 26 lbs max boost and have had nothing but brilliant experiences with Alex.
http://www.intendedacceleration.com/ A lot of people have used them and I have never heard anything but praise. J
1993 2.2 Ur-S4 - IA Stage 3+ 250k and rear ended ![]() 2001.5 2.7 S4 - Heavily modified Stage 3+ |
#5 | |
If the $1200 quote was only for ECU removal and chip socketting and chip installation they are about $700 too high. Here is Steve Eiche's contact info through Shadetree: http://www.shadetreesoftware.com/contactus.html
Naturally, IMHHEO(tm), Dave F. aka the Librarian Car and Mods: 93 S4, 1.8t coil pack conversion (First in world using integral POS coil packs (??)), CF (OE), S6 steering wheel, RS2'd, Samcos, MRC, TDS-1, Apikol FMIC, Eibach/Bilstein, BIRA Sys 1, relayed FP Click here to link to the UrS FAQ Thread Start Uncle Dave says "You want my 'high horse, elitist' opinion ?(IMHHEO(tm))Then just post something stupid." Unofficial Chief Cat-herder Vancouver UrS-car club |
#6 |
I have a Stage 1+ and its great for rolling through stop signs in 2nd gear.
Its also great on the highway for getting up to the speed-limiter quickly without having to downshift. Its a Hoppen chip, but only cost about $700. |
#7 | |
http://www.hoppenmotorsport.com/Audi.S4.S6.Tuning.htm
#8 |
Thats exactly what I have. In fact, when I got the new S6, I sent them back down to Florida with the new S6 cpu, and Mike added the socket and installed them for me and sent it right back. They had been in my S4.
Here's a picture of what they look like... I also recommend the "Reliability Items" below if you dont have them already, or something comparable. The 110 Sport By-Pass Valve is an upgrade over the original, and the K&N filter helps airflow and lasts. You're also likely to blow a hose with a Stage 1+ kit, if they are originals, I blew 2. Most kits contain 3 silicone hoses for ~$350. The 2 hoses Hoppen shows are the 2 hoses I eventually blew. 034 sells them individually also. Last edited by GoHeels; 02-16-2012 at 11:53 AM. |
#9 |
Highly UN-recommend the K&N filter. Not effective at removing dust and grit. Not a major intake restriction in a turbo engine. Risk of over-oiling and contaminating and damaging the MAF. Go new OE paper filter. Better/less risk.
#10 |
I could not agree more, in fact I've been told that the Mahle flows better than the K&N. At $12 there is hardly a reason to use anything else given the risk (and the lack of reward).
To answer your earlier question about lag, Ned and Alex's 3+ ECU update reduced lag on my car. Going to a stiffer WG spring and the billet diverter also helped things (although the diverter only helps if you're shifting well). J
1993 2.2 Ur-S4 - IA Stage 3+ 250k and rear ended ![]() 2001.5 2.7 S4 - Heavily modified Stage 3+ Last edited by Joe100S; 02-16-2012 at 04:36 PM. |
| Tags |
| avant, build, chip, eiche, s6, steve, urs6 |
