Go Back   AudiWorld Forums » Technical Discussion » Motors » 2.7T V6 Discussion
Old 02-05-2012, 06:34 AM   #1
2004 allroad caledonia
Default 2004 allroad torque converter clutch performance or stuck on???
I'm a new owner and my engine warning light came on and this was the code or found problem? I hv done some reserch and found anything from high fluid level, possible clutch solenoid falure. any suggestions or help would be appreciated ... also how do I remove the warning light w/o going to a dealer?
2004 allroad caledonia is offline   Reply With Quote
Old 02-08-2012, 03:08 PM   #2
rohit13
vag-com to clear the code. no other way unless you want to involve a mechanic or dealer.
how many miles are on the car? sounds like your torque converter is shot. there is a seal inside that deteriorates. have you changed the oil yet?
rohit13 is offline   Reply With Quote
Old 04-07-2012, 05:07 AM   #3
vtraudt
Send a message via Skype™ to vtraudt
Posting your error code would help with diagnostic.
TIP trans are famous for the code:
P0741 17125 TORQUE CONVERTER CKT PERFORMANCE OR STUCK OFF/NO POWER TRANSFER
1998 Passat 1.8T manual; Kraftwerk Turbo TM2, 550cc Bosch EV14, FSI coils, 3" MAF, 3" DP, high flow manifold, S4 clutch, single mass FW, FMIC, custom TIP, Kraftwerk Tune
1999 Passat 1.8T manual; Kraftwerk Turbo TM3, 550cc Bosch EV14, FSI coils, 3" MAF, 3" DP, custom TIP, FMIC, Kraftwerk Tune
2002 Audi Allroad 2.7T quattro manual; Kraftwerk Turbo TM4, 750cc Bosch EV14, FSI coils, stg 5 clutch, FMIC
2001 Audi Allroad 2.7T quattro manual; custom stg 1
1996 Audi A4 2.8 quattro automatic. Stock. Issues: heated seats not working (from neer model), ignition lock/key hangs, TERRIBLE gas mileage.
www.regulatorfix.com
www.kraftwerkturbo.com
vtraudt is offline   Reply With Quote
2001, 2004, allroad, audi, clutch, code, converter, conveter, failure, problem, road, sensor, siloinoid, solenoid, torque
HTML code is Off
