#1 | ||
1996 Audi A4Join Date: Oct 2011
#2 |
Doesn't seem there is much activity on this forum anymore but your'e not alone. I am picking up an AFC 12 valve from a local salvage yard tomorrow to rebuild for my car.
I'll be making a thread about it when I get on the move with it, and I'll be watching yours as well. Information seems to be scattered for these 12 valves so if you run into anything I have lots of part numbers for gaskets, replacement parts, etc from the dealership, victor reinz, etc. I also have a lot of specs and such saved as well. Don't be afraid to shoot me a PM if your having a hard time finding anything. I've made enough calls and done enough research preparing to rebuild this thing that it would put a warm fuzzy feeling in me to save someone else that trouble!!!
#3 |
I just did one this fall. I bought a 94 cabriolet with a bad engine and swapped in a junkyard one. If you guys need anything I have just about an entire engine in my basement. It's AAH though so the oil pans and EM are different.
1994 Audi Cabriolet (now with 5 speed!) 1994 Audi Cabriolet - the really really crappy one 1995.5 Audi S6 1993 Audi 90 CS Quattro (sold) |
#4 |
Do you know if an AAH code 2.8l engine from a FWD 93 100 will fit drop directly into my 92 100cs quattro wagon?
#5 |
The engines are both AAH. They're exactly the same.
The only problem you'll have is the flex plate bushing on the crankshaft of the engine from the auto trans car. See this thread for details... http://forums.audiworld.com/showthread.php?t=2594499
#6 | |
#7 |
Sorry I thought there weren't any automatic quattros other thaN the V8 until the B5 / C5 generation.
If they're both auto it's plug and play
#8 |
1993 Audi 90My Garage Join Date: Oct 2008
lucky that you dont have to mess with that dang bushing!!! anyways, take pix, very interested in your progress
1993 Audi 90CS Quattro (loving it) *new front struts, 034 control arm bushings, tie rods. mount savers. B5 sport rear springs/socks, B5 sport swaybar, B5 upper a-arms, 034street density trans mounts,17" ASA, head lights, aux gauges. blue plasma instrument cluster, A4 3 spoke steering wheel, aluminum subframe mounts) *replaced a motor at the end of 2008, gasket matched heads, ARP head studs, air box velocity stack, 4 to 3 wire MAF conversion, 18.5lbs flywheel with SPEC stage 2 clutch. 1975 VW bus (gone) 1973 VW Super Beetle (what was i thinking?) 1968 VW Bug (my pride and joy) *2.5 inch front drop and disk brake conversion, *2110cc motor (in progress)new wiring harness,3 inch wider fenders all around, 195/45r15 front and 195/65r15 rear tiers 1991 GMC Sonoma RWD, manual, 4 banger (gone) 1979 Suzuki GS750EN with 31k original miles 1981 Suzuki GS750L (will be on a chopping block for a bobber) 1981 Yamaha XV920 1983 Yamaha XV750 (for g.f.) 1985 Dnepr MT10-36 (stolen) 1992 Dnepr MT11-32 (also stolen) |
#9 |
1995 Audi 90Join Date: Aug 2012
Hows the rebuild going ?? i would be excited to see how it turns out for you since i am buying one of these as a project this weekend
| Tags |
| 12v, 28, 28l, 96, a4, audi, diy, engine, flex, forum, glastra, jack, plate, rebuild, rebuilding |
