Go Back   AudiWorld Forums » Technical Discussion » Motors » 2.0T FSI Discussion
Old 01-30-2012, 07:20 AM   #1
frankvan
1989 Porsche 911
My Garage
Question 06 2.0T FSI oil leak
I'm looking at a seemingly "perfect" 06 A4 except for one thing, there is a small oil leak from the back of the engine. It appears to be coming from a cover at the back that has the vacuum line going to a splitter and to the brake booster. Looks like a fairly easy fix - remove a few bolts, replace gasket. Can someone tell me what this thing is called at the back of the engine so i can get a quote from a dealer or independent?
(FWIW, i'm fairly handy and confident i can fix myself - i've changed a clutch on a 911! Just want a quote for negotiating).
If needed, i can probably get a picture of it.
frankvan is offline   Reply With Quote
Old 02-16-2012, 07:02 AM   #2
TKR
It's maybe a similar problem I had with my 2005 2.0TFSI quattro. Vacuum pump gasket leaked. Mine is European model, BGB engine, but maybe US is identical.
Early 2.0TFSI engines had a pump number 06D145100E and newer pumps are 06D145100F. The gasket is different and in different position in F model.
I tried to fix my E-series pump leak with new gasket (part no 06D145117), but still oil coming out. Finally the solution was to change the whole pump.
It's quite a expensive at least here in Finland, but I managed to find a new one from eBay ~70eur.
You can fid some pictures in Finnish Audi discussion forum here.
TKR is offline   Reply With Quote
06d145100f, 20, 20t, a4, audi, common, engine, fsi, hose, leak, leaks, oil, pump, tfsi, vacuum
