Go Back   AudiWorld Forums » Technical Discussion » Motors » 12v V6 Discussion
Old 01-24-2012, 01:38 PM   #1
njdrsubaru
1993 Audi 90
Send a message via AIM to njdrsubaru
Default Head gasket info needed...
so im biting the bullet and doing the head gasket on my 90q
but i need some info to do this
what is the tightening sequence for the heads? and the torque?
thanks in advance
njdrsubaru is offline   Reply With Quote
Old 01-25-2012, 08:21 AM   #2
CRAZY_RUSSIAN
1993 Audi 90
My Garage
here is your answer
http://12v.org/maintenance/repairs/headgasket.php
1993 Audi 90CS Quattro (loving it)
*new front struts, 034 control arm bushings, tie rods. mount savers. B5
sport rear springs/socks, B5 sport swaybar, B5 upper a-arms, 034street density trans mounts,17" ASA, head lights, aux gauges. blue plasma instrument cluster, A4 3 spoke steering wheel, aluminum subframe mounts)
*replaced a motor at the end of 2008, gasket matched heads, ARP head studs, air box velocity stack, 4 to 3 wire MAF conversion, 18.5lbs flywheel with SPEC stage 2 clutch.
1975 VW bus (gone)
1973 VW Super Beetle (what was i thinking?)
1968 VW Bug (my pride and joy)
*2.5 inch front drop and disk brake conversion, *2110cc motor (in progress)new wiring harness,3 inch wider fenders all around, 195/45r15 front and 195/65r15 rear tiers
1991 GMC Sonoma RWD, manual, 4 banger (gone)
1979 Suzuki GS750EN with 31k original miles
1981 Suzuki GS750L (will be on a chopping block for a bobber)
1981 Yamaha XV920
1983 Yamaha XV750 (for g.f.)
1985 Dnepr MT10-36 (stolen)
1992 Dnepr MT11-32 (also stolen)
CRAZY_RUSSIAN is offline   Reply With Quote
Old 01-25-2012, 08:40 AM   #3
njdrsubaru
1993 Audi 90
the picture for the sequence doesn't come up
Old 01-26-2012, 03:24 PM   #4
hubturn
Assuming a 12v here.
hubturn is offline   Reply With Quote
Old 01-26-2012, 04:14 PM   #5
njdrsubaru
1993 Audi 90
thank you very much 8)
