#1 | ||
#2 |
2000 Audi A6Join Date: Mar 2010
All the formal publications are going to tell you how to do the engine "audi's" way. Which is the motor itself out the top. I've found that on any audi we've done at my shop, it's easiest to put the car on a lift or jack stands, remove the from end, core supports etc, like your doing a timing belt. Dissconnect all the axles and prop shafts, undo the exhaust at the clamps around the middle of the car, undo the shift cable on the side of the transmission, open the e-box and dissconect all the electrical from the computer and ground studs near the shock towers, this will allow the harness to come with the motor. Remove the heater core hoses by the fire wall and feed them through the grommet in the bottom of the plenum chamber. Remove the power steering, ac pump, alternator, various lines and hoses on each side of the engine, then hold up the engine with a engine hoist and lower the sub frames no need to disconnect from the wheels, undo the 4 motor/tranny mounts from the subframe and drag engine trans and exhaust out the front of the car. I first learned this method from a video on youtube. it hasn't failed me yet and we always beat book time.
#3 |
Audi's way is not out the top. It is removing front end and dropping engine and trans as one unit on a hydraulic table
#4 |
yea i pull the front end off, and then just pull the engine out straight forward. You can leave the trans attached if desired. Subframe must be removed. Really you could do the turbo swaps with the engine installed. Just support it and remove the subframe and it should be accessible.
1992 Audi 100 CS Quattro 1990 Audi 200 Avant Turbo Quattro 1991 Audi 200 Turbo 1999 Audi A6 Avant |
#5 |
2001 Audi AllroadJoin Date: Apr 2011
I recently pulled one out the front, like Prospeeder and Tuppidsay mentioned. I didn't need to remove the subframe though. Things are easy to work on when the engine's out.
#6 |
Not sure if you guys have seen this video but, it definitely is easier to familiarize yourself with the product once it is visible. At least for me it is. http://vimeo.com/5238276
AUDI ALLROAD Metric: 5 X 112.. Standard: 5 X 4.41 ..Stud size: 14 X 1.5b HUB BORE 57.1 --------------------------------------------- http://www.audiworld.com/model/Check your model's Tech specs. & features. http://www.audiworld.com/tech/eng.htmlAudiworld's DIY/How to's |
#7 |
Hey whats up man, I have a question and I think you can help me. I own a 2003 Audi A6 2.7t tip tranny, and everything is stock, i put in a cold air intake. Well, I put in a stage 3 ECU well tried too, and my car didnt want to start, it would turn over but didnt start. We hooked it up to a revotechnik and it didnt tell us what was wrong. But we took it out and put the OEM one back in and it ran fine. Can you progress me through steps or things i need to do for my stage 3 ECU? Thanks.
#8 | |
Either way, upgrading should be done(For the safety of the engine and tranny) as follows: Stage 1 = ECU Chip (Revo/APR/JHM/ etc..) Stage 2 = Chip + Catback Stage 2+ = Chip, Catback + Downpipes Stage 3- = add ko4/FT turbos Stage 3 = add fueling(injectors/fpr/ecu) You can also find this info. as here: http://www.audizine.com/wiki/index.p...S4#Chip_Tuning .. Another great site is www.allroadfaq.com
#9 | |
| Tags |
| 2002, 27, 27t, 2t, a6, audi, automatic, bentley, quattro, removal, replacement, replacing, replacment, trans, turbo, upgrade, write |
