#1 |
1994 Audi Cabriolet (now with 5 speed!) 1994 Audi Cabriolet - the really really crappy one 1995.5 Audi S6 1993 Audi 90 CS Quattro (sold) |
#2 |
I have the zip in style and it is not easy to get it tight, so it's sloppy looking.
In fact I plan on taking it to an upholstery shop to see if they can do anything with it to firm up the top. Will let you know... I would stay with black, holds up the longest without a doubt, white, grey, tan, look good at first... but collect dirt very easily that doesn't show up nearly as bad on black, IMHO.
----------------------------------------------- 95 Red Cabriolet |
#3 |
1998 Audi CabrioletJoin Date: Mar 2010
I got a top from this guy for less than 300, and will be installing it myself for this upcoming spring...
http://www.ebay.com/itm/Audi-Cabriol...item3f09ca4567 |
#4 |
I've done the universal zip in. My next step is to try a construction grade glue gun and see if it holds the edge of the top to the window. That would seem more in line with the stuff I removed when I replaced the window. Makes some sense to me as the original had the copper wire imbeded in the "adhesive" to heat it up when voltage was applied during assembly. Contact cement, etc., has been a failure.
#5 |
Do any of you guys have the Bentley instructions for removal/replacement of the top? I have Bentley for my 90 - not the cab
#6 |
Can someone post a pic and show me what the zip in style looks like. I've heard of them...but never seen one on these cars. A few years ago i polished my rear plastic window, and its holding up pretty good considering...it has bought me a few extra years for sure. I told the wife it was new...she had no idea, so if done properly, you can get good results.
#7 |
hi! how did that rear zip in window end up? I have a 96 cab and it needs a window badly.
Thank you |
#8 |
I ended up not replacing it. I used a rotary buffer and two kinds of polish to buff the plastic window.
It's not perfect by any stretch of the imagination but good enough for me to see a lot better now. Plus, if its not nice enough out to have the top down I'll likely be driving the S6! This was my inspriation for the buffer method... http://www.youtube.com/watch?v=dC848...e_gdata_player
#9 | |
#10 |
Hawkdaddy - go to EMiata.com. That's the guy in North Carolina that makes them. Good pic of the missing teeth in the universal zipper. You have to get it started at the correct point or you get wrinkles in the corner. Mark the zipper on the half connected to the top and the half connected to the window. Then use the old window to mark the new one. Line it up and then start the zipper. It is NOT all that easy, but if you take your time it will work. If I were to do it over, I'd take the old window to a shop and get them to match the zipper, and sew a a new half on. Or, I'd get them to remove the old zipper from the window and stitch it on to new plastic. You'll need a zipper pull. There are alignment notches cut into the old window. Sorry about not getting back to you via PM.
| Tags |
| 1994, audi, cabriolet, forum, rear, replace, replacement, top, window, zipper |
