| A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007-present |
#1 | ||
#2 |
What year is your car. Because I just have my repair a modulemaster.com and my tecnician never remove anything, just took it from the top. My was a Bosh 8.0 and its a 2005 A6 C6. $384 total and 5 year waranty work like a charm no more Christmas tree in my dash.
#3 |
I also have a 2005 c6. I can also take it off the top but I cant see any way to remove the module without removing the pump. Removing the pump is what I am concerned about since Bentley manual states that you have to bleed the brakes if you are replacing the unit with a new one - in my case I would be putting the old one back with a repaired module.
All the DIY are for the c5 and they are able to get to the module via the wheel well but on the c6 there's no way to remove just the module. BTW congrats on the xmas light free car. |
#4 |
I had mines rebuilt at ModuleMaster earlier this year and I could not find anyway to remove just the ABS module. The problem is a metal bracket that stands in the way of two of the four screws for the module. I drained the lines, removed the pump and shipped out my ABS module to get repaired.
-05 Audi AllRoad 2.7T (Current) -05 Audi A6 3.2 (Current) -01 Infiniti i35 (Sold) -94 Acura Legend LS (Sold) -93 Acura Vigor GS (Sold) -89 Civic Si (Sold) Last edited by jujuC6; 12-20-2011 at 08:50 AM. |
#5 |
I finally removed it and drove up to BBA reman in Taunton MA, and they basically said that they would attempt to fix it but they never worked on a 8.0 before and it would a experimental procedure that could take 2 weeks.
Not the type of response I wanted; so I packed and shipped the module off to modulemasters. Now I wait, wish me luck. |
#6 | |
-05 Audi AllRoad 2.7T (Current) -05 Audi A6 3.2 (Current) -01 Infiniti i35 (Sold) -94 Acura Legend LS (Sold) -93 Acura Vigor GS (Sold) -89 Civic Si (Sold) |
#7 |
They repair my in just 4 days..+ they give 5 year of warranty..Good Luck...
#8 |
Yep, 5 year warranty...
#9 | |
#10 |
I just did this yesterday and shipped my ABS module to ModuleMaster. I had to remove the phillips screw holding down the coolant resevoir. Disconnected the harness. Removed the 2 nuts holding the ABS pump to the metal bracket. Removed the upper screw holding the metal bracket. Removed the 2 lower screws holding the metal bracket (hidden under a wire loom). I was then able to carefully "tweak" over the whole ABS assembly away from the bracket just enough to get a wrench on the four E5 Torx bolts. Carefully remove the module straight away from the ABS. After that I wrapped everything in Aluminum foil as suggested by modulemaster. Packaged, shipped, BAM! its off for repair.
Now I just have to deal with lights and sounds of the dash Christmas tree. Just wish the tune was a little less nagging. ;-) |
| Tags |
| 2008, a6, abs, audi, b6, bleed, brakes, c6, e5, exam, mk1, module, removal, s4, tt |
