#1 | ||
2005 Audi A4Join Date: Dec 2009
#2 |
MAF isnt going to cause a miss. And really its impossible to get a proper range from it, as engine running conditions, ambient conditions, elevation, ect will make the readings different. If its missing. Plugs, wires, coils, Power output stage for the coils, or injectors, or mechanical problem, low compression, burned valve. Figure out which cylinders are missing and go from there
#3 | |
#4 |
Well if your connectors are bad, or the spark plugs are the wrong type or really worn out. They will just continue to destroy ignition coil after ignition coil. I would start with a fresh set of NGK, DEnso, Bocshe, OE VW spark plugs and replace all 4 ignition coil connectors and the failed coils and go from there.
#5 |
vacume leak on the upper manifold. the injectors and coil can be tested with an easy ohm tester. they should all read the same. an uncorked compression test on the missing cylinder... and then another will tell you if you have a bad valve. my guess is the manifold leak which is quite common.
| Tags |
| 18t, 2003, a4, air, audi, b6, connector, flow, maf, mass, readings, sensor, suppose, test, voltage |
