Right front drain replacement cost
When I cleared my lines, I only needed to stick my finger up the bladder drain to clear some dead leaves and pine needles. There was about a mason's jar worth of water stuck up there and released once the drain was cleared.
@ pch, didnt get any pics of the Sun Roof Drain outlet by any chance? Also the Q7 in question is a MY 2007, they had the earlier drain hose type that can crush by the cable ties. Perhaps that is why they recommend replace as solution.
@audiblack73, I saved links to earlier threads and pics re sunroof drains in the spreadsheet. Scroll down body faults column. There may be other notes re same. Also check out the Part No & TSB sheet(both sections).
NOTE see the part number and price... 22 bucks at the last count.
In answer to your question. Yes you could probably do it but read up on all possibilities and solutions first.
It could well be just blocked.
Next worst it may be offor loose from its top end connection.
Worst of all it could be kinked. I doubt this because it would have kinked long ago.
Please report back on progress or ask for more help any time.
My experiment so far, found drain holes on sunroof, inserted weed wacker wire, both side got stuck at around end of a pillar, as it is both side so i dont think it is blocked atleast till the end of a pillar. Question is what is this resistance i hate to push it further. Wondering where is the endpoint exactly. Pics any.
Water leak sunroofdrain
I contacted audi usa for this ongoing known problem and i told them i was quoted $1700 from dealership to replace all 4 hoses. They contacted me back and contacted dealer who scheduled my appt and replaced all 4 drains for very low price compared to what i was quoted. Car was out of warranty
s4sd2007
15
01-27-2008 07:23 PM
The Turtle
04-23-2003 06:20 AM
