#1 | ||
#2 |
is the test only available to car with ESP systems ?
#3 |
Have you checked the factory repair manual yet? Mind posting an Auto-Scan so we see which ABS system is actually installed?
Sebastian @ Ross-Tech.com |
#4 |
Here is a photo of what ABS module I have , I have replaced with new unit after original failed but it is the same part# VAg# and version
I have checked factory manual , Bentley does mention abs cycle through cable, but doesn't say if this works with all ABS or specific ones Last edited by audifirst; 12-06-2011 at 08:10 PM. |
#5 |
Please update to a current version of VCDS and post the Auto-Scan as requsted.
#6 |
I have updated the vcds and still nothing included the photos of the screen, and the autoscan
VCDS Version: Release 11.11.0 Data version: 20111111 Wednesday,07,December,2011,10:25:52:39530 Chassis Type: 4B - Audi A6 C5 Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67 75 76 77 Mileage: 260040km/161581miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 078-907-551-AHA.lbl Part No: 4D0 907 551 AH Component: 2.8L V6/5V MOTR AT D03 Coding: 06252 Shop #: WSC 40802 VCID: 6CDC219E1C90E8E No fault code found. ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01V-927-156.lbl Part No: 4B0 927 156 G Component: AG5 01V 2.8l5V USA 8509 Coding: 00000 Shop #: WSC 00000 VCID: 2B5EE282D91E2F6 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl Part No: 8E0 614 111 A Component: ABS/EDS 5.3 QUATTRO D10 Shop #: BB 24334 VCID: 1C3C315E8CB0D8E No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl Part No: 4B0 820 043 Q Component: A6-Klimavollautomat D62 Coding: 00160 Shop #: WSC 02325 VCID: 28541D8EC8E804E No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4B0-959-655-AI8.lbl Part No: 4B0 959 655 H Component: Airbag Front+Seite 0002 Coding: 00106 Shop #: WSC 02324 VCID: 356AC4FA0F5A696 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4B0-919-xxx-17.lbl Part No: 4B0 919 930 J Component: C5-KOMBIINSTR. VDO D10 Coding: 06362 Shop #: WSC 00000 VCID: 2F66F692ED06536 No fault code found. ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 4B0-962-258.lbl Part No: 4B0 962 258 J Component: Central Lock/Alarm D32 Coding: 15949 Shop #: WSC 02325 VCID: 3064F5EEF0384CE No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No: 4B0 959 760 A Component: Sitzmemory D05 VCID: 2B5EE282D91E2F6 No fault code found. ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-173.lbl Part No: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00002 Shop #: WSC 02325 VCID: E0C4C5AE60583CE No fault code found. End --------------------------------------------------------------------- |
#7 |
Thank you. Based on this information it does indeed look like you can't initiate the bleeding via diagnostics/basic settings. The factory manual suggests the use of an external bleeding unit.
| Tags |
| a6, abs, audi, bleeding, c5, ross, tech |
