Go Back   AudiWorld Forums » Technical Discussion » Motors » 3.2 24v VR6
Old 11-26-2011, 10:36 AM   #1
A6newbie
Default c6 error codes
3.2L
Have recently done 55k maintenance, replaced all coil packs, replaced low pressure fuel sensor & ran Lucas fuel injector through a tank of gas. Now have the following errors:
Address 01: Engine Labels: 06E-910-559-BKH.lbl
Control Module Part Number: 4F1 910 559 B HW: 4F1 907 559 A
Component and/or Version: 3.2l V6 FSI 0040
Software Coding: 01050106190F0120
Work Shop Code: WSC 02325 785 00200
VCID: 2A50875EFC97
3 Faults Found:
19545 - Signal Line for Fuel Pump Electronics: Electrical Malfunction
P3089 - 009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 92266 km
Time Indication: 0
Date: 2011.11.25
Time: 09:40:24
Freeze Frame:
RPM: 640 /min
Mass Air / Rev.: 125.4 mg/str
Temperature: 84.0°C
Idle
Pressure: 5.6 bar
Speed: 0.0 km/h
18975 - Low Pressure Fuel Sensor (G410): Intermittent
P2543 - 009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 92269 km
Time Indication: 0
Date: 2011.11.25
Time: 09:54:33
Freeze Frame:
RPM: 704 /min
Mass Air / Rev.: 130.8 mg/str
Temperature: 88.5°C
Idle
Pressure: 4.9 bar
Speed: 0.0 km/h
17546 - Fuel Trim: Bank 2 (Add): System too Lean
P1138 - 006 - Short to Plus
Freeze Frame:
Fault Status: 01010001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 92269 km
Time Indication: 0
Date: 2011.11.25
Time: 09:54:53
Freeze Frame:
RPM: 672 /min
Mass Air / Rev.: 141.7 mg/str
Temperature: 88.5°C
Idle
Time: 409.6 s
Bin. Bits: 00000010
Readiness: 0110 0101
Any Ideas?
A6newbie is offline   Reply With Quote
Old 12-08-2011, 01:20 PM   #2
A6newbie
Default Update
Just to let anyone with the same errors know:
I got the car back from the dealer yesterday.
Replaced #5 fuel injector at the tune of $800.00
Could have replaced all 6 for just under 2k.
006, audi, c6, code, codes, error, jandy, p3089, reset, roadster, rs6, tt
HTML code is Off
