| TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-present |
#1 | ||
2009 Audi TTJoin Date: Nov 2009
#2 | |
#3 |
Actually, we're having the same problem with our TT. After about 10k miles on new tires, the driver rear started cupping and howling, despite having an alignment done when installing the new tires and rotating them after 5k miles. Now they refuse to rotate it because they say we'll feel the front tire vibrate the steering wheel if they move it to the front. They said "the TT's need to be rotated more frequently than other cars" and told us to just consider the current set (with about 1/3 life remaining) garbage until we can get new tires.
I'm interesting to see what you learn with your car.
Ben 2009 Audi A4 2.0T S-Line Avant (1-of-a-kind in the U.S.) 2008 Audi TT 2.0T S-Line Coupe (1-of-a-kind in the U.S.) 2011 Ford F-150 Lariat Limited (#3252 of 3700) Retired: 2003 Ford SVT Lightning / 2001 Ford SVT Lightning / 1993 BMW 740iL / 1990 BMW 535iM / 1986 Porsche 944 Turbo / 1983 Porsche 944 |
#4 |
I changed out the ContiSport Contact3 OEMs at around 15K miles. Not a great tire. I'm at 34K miles now on a set of Eagle F1 GS-D3s, which have been stellar, and am now ready to replace them. Never had any cupping issues with either tire. I'm pretty religious about pressure and wear, but to this point, I've never needed to rotate. Front to back, side to side, the wear has been remarkably even.
I'm on 19" rims with 255/35-19s.
"Whaddya mean 'don't go there'? I live there..." "Understeer is when you see the tree, oversteer is when you hear it..." (Walter Röhrl, former German RWC) '09 TTS Prestige, APR Stage I |
#5 | |
Did you do an alignment right when you mounted the new tires?
#6 |
2011 Audi Q5Join Date: May 2011
Every time I've encountered tire cupping it was ultimately due to shocks at the end of their life or not up to the tasks...
allowing minute up and down movement with every revolution. while rotations are important, it only masks the issue from shocks...
Brilliant Black 2011 Q5 20T P+,MMI,B&O,20" Multi-spokes Pkg w/ Goodyear Eagle RS-A 101V tires http://forums.audiworld.com/album.ph...ctureid=233007 FOR SALE, magnaflow mufflers, Sound and fury here: http://www.youtube.com/watch?v=Ec7idI1BRHI
#7 | |
Nobody is more amazed than I about the wear pattern. Every time I fill up, I have my little ritual: 1. Note the date and mileage in the little log book I keep in the glove compartment 2. Start the pump 3. Lift the hood, check oil, brake fluid, quick visual on the hoses and belts 4. Walk the four corners for a quick check on the tires for wear and the rotors for anything unusual 5. Shut off the pump and log the fuel I look at tire pressure about every two weeks. When the F1s were installed, Big O filled them with Nitrogen, gratis. I was skeptical at first, but I haven't had to adjust any tire but the front left, which must have a very tiny leak somewhere.
#8 |
Hmm, I only have 46k miles on the car, so shock failure/wear seems a little premature, doesn't it? I have the standard suspension (not magnetic ride).
#9 |
My tires started cupping at 4,000 miles. The dealership checked everything out and said the suspension was ok. Isn't that early for problems? I checked the tire pressure every month and set it to recommended specs. Picked up the car new with 200 miles on the odo. Minimal tire noise. Then noticed louder noise at 4,000 miles. Now at 13,000 miles and tires very loud and very noticeable wear on the inside edge of tires.
I'm getting a 4 wheel alignment and new tires but I am just asking if this is a common problem with the the stock alignment specs. |
#10 |
I have a 2005 MkI TT FWD and for the longest time there was no way to align the rear axle. Now they make shims that go in between the hub and axle. Most alignment shops dont even know how to do this as the whole rear wheel assembly must be taken apart and the shims put in. DONT know if the MK II is the same. I know the MkI quatro could be aligned but the FWD couldnt. dont know much about the Mk II . My tires used to cup real bad after about 10,000 to the point where they had to be replaced.
| Tags |
| 2008, 22, a4, audi, avant, camber, cupping, negative, noise, rear, side, tire, tires, tt, wheel |
here:
