S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
secondary air injection issue
Old 11-20-2011, 02:02 PM
s4_sp's Avatar
Default secondary air injection issue
Recently, my S4 (B6, 2005-early-year-model, 110k miles) gave me ECL code that said catalytic converter (bank-2) failed. So I went to an indy-shop to replace it at the cost of $1500.
After that pricey repair, now I have another ECL code that says "secondary air injection level (bank 1&2) has reached its lower limit." The mechanic at the indy-shop told me that I may ignore that error code because it is only about the engine cold start. He also said that error code is very common in many Audis'.
However, I really concern if it would be ok to drive with that, because it is a part of exhaust system of the engine. I think it has to be fixed eventually. But this time, I'd like to spend some time to do more research to root cause the issues that I am having or will potentially have soon.
So the question is, would it be ok to drive with this problem for a while? Or is it a critical issue that I should fix this immediately?
Many thanks to you in advance.
sugaryling
Audi 100 / A6 (C4 Platform)
03-25-2012 12:03 PM
04/A6/2.7t/S-line
9
08-27-2008 10:38 AM
sjal2
11-16-2005 07:41 AM
2001AWDFUN
11-28-2004 05:29 AM
TTinGables
TT (Mk1) Discussion
11
10-01-2001 05:51 AM
Quick Reply: secondary air injection issue
