Go Back   AudiWorld Forums » Technical Discussion » Electronics » VAG-COM Discussion
Old 09-17-2011, 11:38 AM   #1
gdaniel
Default Satellite Radio Measuring Blocks
My 05A8 Sirius radio (0F) is intermittent. Measuring blocks 5 and 8 show the following:
Audio ON: 5 Signal Strength 4 (best signal per TSB)
8 Service/Provider Info: 0
Terrestrial: 194
Sat: 194
Audio OFF: 5 Signal Strength 1 (no signal)
8 Service/Provider Info: 3
Terrestrial: 194
Sat: 194
Summary: When there is no audio, there is no signal and Service/Provider info changes from 0 to 3. What do the values in block 8 mean and/or where do I find this information. I don't find it in the Bently manual?
gdaniel is offline   Reply With Quote
Old 09-19-2011, 09:59 AM   #2
Theresias
Theresias's Avatar
Mind posting a complete Auto-Scan please? Do you have these issues in general or just at certain locations?
Sebastian @ Ross-Tech.com
Theresias is offline   Reply With Quote
Old 09-19-2011, 04:01 PM   #3
gdaniel
Default Autoscan
Here it is.The TPMS is deliberately turned off, but the digital radio problems preceded this. Aside from some of the codes thrown, nothing other than digital radio 0F is troublesome. That's why I am trying to identify the 0F measuring values. Thanks for your help.
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAULL44E85N015970 Mileage: 124090km/77105miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Not registered 0011
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 J HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E2760219
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 28551370E263
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 S HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0020
Revision: --H01--- Serial number: 0054638
Coding: 0000002
VCID: 3261F118D4BF
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008597
Shop #: WSC 22145 000 00000
VCID: 22410158845F
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 D
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0E2760219
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8B5E3B01283
Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 5
Reset counter: 192
Mileage: 118528 km
Time Indication: 0
Date: 2011.07.27
Time: 19:50:26
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
VCID: 234F045C9B45
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 G HW: 4E0 035 729
Component: Interfacebox H43 1070
Revision: 00000000 Serial number: 346CR057520677
Coding: 0000003
VCID: 244D07409E4B
Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 C
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000062455
Coding: 1052993
VCID: 1C3D3FA0A63B
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H12 0210
Coding: 0123123
VCID: 3163FE14D1B9
Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000037
Shop #: WSC 02313
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7174611
Shop #: WSC 00000 000 00000
VCID: 1B3F3CBCA335
Address 0F: Digital Radio Labels:
VCID: 55AB6A848591
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
VCID: 244D07409E4B
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0012141
VCID: E5CBDA4455F1
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 G HW: 4E0 920 950 G
Component: KOMBIINSTR. VDO H53 0210
Revision: D05 Serial number: AUDID3E2004417
Coding: 0000233
Shop #: WSC 03830 444 12526
VCID: 28551370E263
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H10 0080
Revision: 10 Serial number: 1900305217018E
Coding: FCFE7BDC1B7904
VCID: 2757104CEF7D
2 Faults Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 7
Reset counter: 189
Mileage: 120083 km
Time Indication: 0
Date: 2011.07.29
Time: 18:34:35
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 109
Reset counter: 154
Mileage: 121820 km
Time Indication: 0
Date: 2011.08.10
Time: 16:14:14
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
VCID: D8B5E3B01283
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 192
Mileage: 118528 km
Time Indication: 0
Date: 2011.07.27
Time: 19:50:26
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: 2A51E978FC6F
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 4071530
VCID: 234F045C9B45
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 N HW: 4E0 919 887 C
Component: MNS US H44 0740
Revision: 00000000 Serial number: 378CR057518143
VCID: 3875C33032C3
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000501000023
Coding: 0003477
VCID: 1D3B32A4BD21
Address 42: Door Elect, Driver Labels: None
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM002 0060
Coding: 0032364
VCID: 20450B508A53
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H08 0020
Revision: 00200008 Serial number: W040806130011
Coding: 0065086
Shop #: WSC 22102 444 54341
VCID: 2A51E978FC6F
Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Part No: 4E0 907 719
Component: Neigungssensor H03 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000011995
Coding: 0000016
VCID: 254B1A449571
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000055979
Coding: 0010111
VCID: 1E3935A8B027
Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Address 52: Door Elect, Pass. Labels: None
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM002 0060
Coding: 0032364
VCID: 20450B508A53
Address 53: Parking Brake Labels: 4E0-910-801.lbl
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
VCID: 1D3B32A4BD21
Address 55: Xenon Range Labels: None
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000001
VCID: E2C1C15844DF
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 396CJ057505310
Coding: 0000002
VCID: 234F045C9B45
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000003269
VCID: 20450B508A53
Part No: 4E0 915 105 A
Component: von VA0 4807170894
Coding: 344530393135313035412056413034383037313730383934
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0060
Coding: 0032364
VCID: 1E3935A8B027
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000700030971
Coding: 0202127
VCID: DFC7C8AC77AD
2 Faults Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 182
Reset counter: 154
Mileage: 121820 km
Time Indication: 0
Date: 2011.08.10
Time: 16:19:53
Freeze Frame:
Speed: 0.0 km/h
Temperature: 26.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 93
Mileage: 118470 km
Time Indication: 0
Date: 2011.07.27
Time: 10:23:00
Freeze Frame:
Speed: 102.0 km/h
Temperature: 22.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 753 S HW: 4E0 035 753 A
Component: SDS 3501 US H45 0550
Revision: 00000000 Serial number: 00000502250420
Shop #: WSC 12336 024 394758
VCID: 356BCA0425D1
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0060
Coding: 0032364
VCID: 1E3935A8B027
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08720504000342
Coding: 0001208
VCID: 21430E548159
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 A HW: 4E0 862 335
Component: Handyvorb2 H10 0120
Revision: 00000000 Serial number: 00000007517593
Coding: 0010900
VCID: 21430E548159
End ---------------------------------------------------------------------
Old 09-20-2011, 02:41 PM   #4
Uwe@Ross-Tech.com
Audiworld Premium Sponsor
2006 Audi A3
Uwe@Ross-Tech.com's Avatar
VCID: 55AB6A848591
Looks like it's not communicating reliably at all. We need to see which one Sat Receive you have. Please access it manually, use the [Advanced ID] function, and click [Save], then use the [Fault Codes] function and again use [Save], then post the results.
-Uwe-
http://www.Ross-Tech.com
Uwe@Ross-Tech.com is offline   Reply With Quote
Old 09-20-2011, 06:40 PM   #5
gdaniel
Default Advanced ID and Fault Code
Tuesday,20,September,2011,19:26:17:19588
VCDS Version: Release 10.6.4
Data version: 20110418
Control Module Part Number:
Component and/or Version:
Software Coding:
Work Shop Code:
VCID: 55AB6A848591
Advanced Identification
Serial number: AUZ4Z7E10
Identification:
Revision:
Date:
Manufacturer number: 0042
Test stand number: 0001
Software
M01.09.11
M2.00
Misc.
VCDS Info:
Labels: 4E0-910-593-SIR.lbl
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Control Module Part Number: 4E0 910 593 B HW: 4E0 035 593
Component and/or Version: SDAR
Software Coding:
Work Shop Code: WSC 00000 000 00000
VCID: 26491D48E877
Old 09-20-2011, 06:51 PM   #6
gdaniel
Uwe
I forgot my manners when I submitted the requested info above. Thanks very much for your help.
Gary
Old 09-21-2011, 03:17 PM   #7
Uwe@Ross-Tech.com
2006 Audi A3
Values in Group 008 are well documented in the label file for that module. Access the 0F module, go to Measuring Blocks, and look at the upper left corner of the screen. You'll find the name of the label file there in "hyperlink format". Click it. It will open in Notepad automagically.
-Uwe-
Old 03-12-2012, 02:48 PM   #8
Orlan24
2006 Audi A8
Hey Uwe & gdaniel,
I was reading your post and I think I'm having a similar issue to what you experienced with my 2006 A8. My sirius is linking almost all the time and almost useless and very frustrating. I find myself taking my wife's A4 to work just so I can listen to the howard stern show in the morning. I had Audi check out the unit and although I don't know if they actually checked anything but they said the unit is fine and that if they wanted me to drop the headliner and check the antenna, it would be about $400 in labor time and potentially not fix anything. I'm not sure how to verify that my antenna is ok or if I should just swap in an XM unit and see if that works. I was wondering how you verified that your issue wasn't caused by your antenna. Any insight would be greatly appreciated.
Orlan24 is offline   Reply With Quote
Old 03-13-2012, 06:59 PM   #9
gdaniel
The SAT receiver is module 0F. Using VCDS, the terrestrial and sat antenna health are shown at measuring block 8. "194" indicates that the antennas and cables are functioning properly. I then replaced the Sirius module with an XM module and the linking was gone. See my post here:
http://forums.audiworld.com/showthre...2815440&page=2
Old 03-19-2012, 05:38 AM   #10
Orlan24
2006 Audi A8
So you are attributing this issue to a faulty Sirius module?
035, 129, 4e0, 4e0910593l, 593, 907, a8, angle, audi, control, h06, module, satellite, sensor, steering, unit
HTML code is Off
