Old 09-16-2011, 08:33 PM   #1
JT2385
Account #: 222336
Default 2001 AUDI A6 2.8L (FWD) TROUBLE CODES
Hi, I need some help. I have a few trouble codes and I would like some expert advice on what might the problem be.
1) 18057.P1649
2) 16502.P0118
3) 16514.P0130
4) 16825.P0441
JT2385 is offline   Reply With Quote
Old 09-17-2011, 03:36 AM   #2
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
If really want help, at least take five minutes to look up the codes.
4Driver4
Growing old is mandatory; growing up is optional.
1980 VW Scirocco (mid-life crisis car)
1983 Mazda RX-7 (revolutionary sports car)
2003 Mini Cooper S (just because)
1995 Mazda Miata, Superdupercharged(anti-Audi)
1999 Mazda Miata SSB (track beotch, no plate)
2003 GMC Yukon Denali XL (the anti-earth)
2004 Dodge Dakota (hey, at least it's stick and 4x4)
Old 09-17-2011, 05:27 AM   #3
rohit13
Account #: 196869
1) 18057.P1649
2) 16502.P0118
3) 16514.P0130
4) 16825.P0441
Po441 is incorrect purge flow which has something to do with the N80 valve or the canister.
rohit13 is offline   Reply With Quote
Old 09-17-2011, 07:19 AM   #4
5v/cyl
Account #: 196934
+1 Google is your friend.
'99 A4 2.8 Tip Quattro
'03 Allroad 2.7t Tip (Gen I's + Bilstein's)
'87 Toyota FJ60 LandCruiser
5v/cyl is offline   Reply With Quote
Old 09-17-2011, 07:25 AM   #5
radhaz
Account #: 105935
radhaz's Avatar
http://wiki.ross-tech.com/wiki/index...ry:Fault_Codes
2011 A3 S-Line Monza Silver Metallic
posting from central California
radhaz is offline   Reply With Quote
Old 09-19-2011, 09:13 PM   #6
JT2385
Account #: 222336
I did look up the codes, but I get various results. Which is why I asked for help from an "Expert". Thank you for your smart remark.
Old 09-20-2011, 03:02 AM   #7
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
Or http://www.bentleypublishers.com/tec....dtc.table.htm
Bank one is right side. Always.
4Driver4
Old 09-20-2011, 05:27 AM   #8
Huskerbob
Account #: 219486
Huskerbob's Avatar
Default Codes
You might try searching for codes by entering only the part from "P" on. So P1649 yields an ABS code, P0118 is a coolant temp sensor, P0130 is an O2 sensor and P0441 is an evap system purge flow. If you add Audi to the front of the search string you also get pretty good results especially if you drill down to an Audi link. So audi p1649 yields ABS problem and an Audi solution.
Huskerbob is offline   Reply With Quote
1999, 2001, 28, 99, a6, audi, code, codes, forums, location, n80, p0118, p0130, p0441, symbols, trouble
Forum Jump
