Go Back   AudiWorld Forums » Technical Discussion » Motors » 4.2 V8 Discussion
Old 09-11-2011, 04:25 AM   #1
BOsA6
Default 2005 4.2 timing set up??
I am at the point on replacing a broken guide on my 2005 A6 4.2. I am also replacing all the chains and the tensioners aswell bank 1 cam adjuster. Does anyone have any information on how to make sure the timing is correct.Prior to removing the motor it was misfiring on all cyl. Any pointers??
BOsA6 is offline   Reply With Quote
Old 03-04-2012, 07:37 PM   #2
pkvoss
1994 Porsche 968
My Garage
What did you end up doing? Would you please share your outcome? Thanks!
pkvoss is offline   Reply With Quote
Old 03-05-2012, 06:52 AM   #3
BOsA6
I ended up purchasing the Bentley DVD for all the info on the proper tools needed and procedures. I replaced both cam adjusters all 4 chains,guides and tentioners. It was a big job to do but ordered the proper tools to use when replacing the cam adjusters.Attached are some pics for you.After all was done I also replace all oil check valves under the intake as well the complete intake. There was a broken plasitc piece that I could not repair! I also replace all the shocks with AL-KO and lowered the car with Eibach Pro Kit (1.0-1.2"). I had removed the mufflers too and replace them with straight exhaust pipes and welded Magnaflow s/s tips. sounds amazing!! Nothing but thumbs up with the car. Come spring I will put my summer 18" rims with the new Michelin Pilot Super Sport 245/40/18 and post those pics.
Old 03-05-2012, 07:15 AM   #4
BOsA6
Here is the pics front the beginning of the motor work,Enjoy
Old 03-05-2012, 07:44 AM   #5
BOsA6
The begining of the tare down. We checked for any damage on the cams and top end..
Old 03-05-2012, 07:51 AM   #6
BOsA6
This is were we started to find damage and broken guides..
Old 03-05-2012, 08:11 AM   #7
BOsA6
Here is one of the broken guides..In Audi's Bulletin's they say if you have a chatter noise when cold start up that it is normal... and not a problem..well I had that noise upon startup and it eventually gotten worse and worse and this is what can happen
Old 03-05-2012, 08:29 AM   #8
BOsA6
After over a restless night of sleep of finding the passenger side cam adjuster exploding inside of its self(bank)! I ordered both sides.. aswell I ended ordering all new parts for the rest of the timing components to know that I did the job right the first time!
Old 03-05-2012, 09:42 AM   #9
BOsA6
After the install of the motor,shocks and springs. The car now runs and drives amazing no more rattles,chattering and misfire!! When all this started I went to the dealer to find out what can cause all this and they "never" had this type of problem.I also asked around locally to get some hints but nothing.I went on forums and found nothing either. So I decided to do this here at my shop even though I have never performed this extensive of a job(European) but we did it and can say now bring it on!! Here is my web site www.everythingautomotive.ca
Old 03-05-2012, 06:03 PM   #10
Prospeeder
Why is it audi/Vw cant make an engine with timing chains last. VR6 and W8/W12 engines have the same stupid long, complex, over done chain setup with the cheapest plastic they could find to use as guides. 80k or less, rattles and problems. Almost wish they just stuck to belts.... How many miles does yours have on it?
1992 Audi 100 CS Quattro
1990 Audi 200 Avant Turbo Quattro
1991 Audi 200 Turbo
1999 Audi A6 Avant
Prospeeder is offline   Reply With Quote
42, adjust, audi, misfire, misfires, p0174, random, s4, timing
HTML code is Off
