Go Back   AudiWorld Forums » Audi Models » Audi A8 / S8 » A8 / S8 (D2 Platform) Discussion
Old 08-22-2011, 06:16 AM   #1
KEVOZS8
Default problem with the TFT Sensor
I have an Audi S8 1998 model with the 5 Speed automatic transmission the car runs prefect but recently i have noticed that when the car is at normal temperature or after driving for about an hour it begins to act strange . it doesn't shift from second to third on drive unless you select the tip mode and you select the third gear . i have hooked it up to the scanner and it gave me the following : transmission fluid temperature sensor .
Can anyone please advise me how to replace it or how can i fix this problem !
KEVOZS8 is offline   Reply With Quote
Old 08-22-2011, 06:03 PM   #2
tozoM8
tozoM8's Avatar
It is in the trans wiring harness inside the trans behind the pan.
http://audipages.com/tozo/tn_trans%20temp%20sensor.JPG
'05 Porsche Cayenne Turbo titanium on black
'01black on black allroad 2.7T
'01 black on black twin turbo S8 6 speed manual(euro TDI 6th gear), RNS-E, Passport SRX SOLD
tozoM8 is offline   Reply With Quote
Old 08-23-2011, 12:50 AM   #3
KEVOZS8
Thanx for your reply and help i just want to know what do you mean by pan ? the oil filter ? or the valve body inside the transmission ?
Old 08-23-2011, 04:45 AM   #4
silverd2
silverd2's Avatar
Both are. Filter attached to valve body.
Pics in this tutorial:
http://www.audipages.com/Tech_Articl...servicing.html
Mine: '01 A8 SWB
Hers: '03 Allroad 2.7T
Dog's: '90 Passat wagon
silverd2 is online now   Reply With Quote
Old 12-01-2011, 12:52 AM   #5
KEVOZS8
Hi Again , Thank you for your help but i cant find it thru the websites such part ( new Wiring harness of the transmission (5HP24A)) if you can give me a link i will be very glad and appreciated .
Old 12-01-2011, 07:25 AM   #6
silverd2
silverd2's Avatar
The part # for your car is: 01V 971 661 C
The temp sensor is integrated into the wiring harness.
U.S. suppliers price it from $200-$260 USD.
Cheapest I found was at:
http://genuineaudiparts.com/partloca...?siteid=214407
...but don't know if they ship internationally.
With the part # as reference, you can likely find it locally...where ever you may be.
Mine: '01 A8 SWB
Old 02-21-2012, 11:01 PM   #7
KEVOZS8
I got the part last week but i want to know is it from the Sensor faulty itself or my trans oil is overheating ?do i need to flash the radiator hoses first then replace the harness ?
Old 02-22-2012, 05:10 AM   #8
silverd2
silverd2's Avatar
What was the original code you got? ...exact number.
Mine: '01 A8 SWB
Old 02-22-2012, 07:38 AM   #9
KEVOZS8
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
Old 02-22-2012, 02:08 PM   #10
silverd2
silverd2's Avatar
High ATF temp should not trip that code.
It indicates an open circuit or short circuit in the harness...or a faulty sensor.
If you haven't already, I would check the harness connection on the outside of the trans first...bad connection, oil soaked, corrosion, etc.
Mine: '01 A8 SWB
01v, 322, 927, a8, audi, d2, fix, p1507, s8, sensor, tft
