Massive Coolant Leak near firewall
Old 08-12-2011, 01:47 PM
jensen_jenniferl's Avatar
Default Massive Coolant Leak near firewall
I just recently replaced my water pumpback in May due to I had massive amounts of water and coolant leaking from my car. The heads were checked and nothing was warped. The leak stopped for about a month and a half and now the problem is back again. This time, the reservoir will not even hold water at all. With the car completely off, I put the water in the reservoir and whithin a minute, all the water has leaked out. I took it to a master mechanic and he said the water is coming from the back of the block near the heater hose to the firewall. I had all the hoses checked for the radiator, coolant lines and heater hoses. No tears or leaks. He is a master mechanic and does not regularly work on Audi's. He could not tell me what the part was called, so I am inclined to take whatever he says as BS. What could this be? I have been reading a lot about auxillary water pumps, j plugs, and compression rings. Someone please help!
Old 08-12-2011, 01:51 PM
tester123's Avatar
Can you visually locate where the water leak is?
Also, What model/year?
Old 08-12-2011, 01:53 PM
2001 Audi A6 Quattro 2.7T
Old 08-12-2011, 01:58 PM
[QUOTE=tester123;24182744]Can you visually locate where the water leak is?
The mechanic said he could visually see where the water was coming from the end of the heater hose off the back of the block to the firewall. He also had my car torn apart though.
Old 08-12-2011, 03:02 PM
5v/cyl's Avatar
Probably the black cross pipe on the back of the engine that goes between the two heads. Sealed with O rings on either end. One is probably leaking and badly by the sounds of it. $.25 O ring, but absolute PITA to get to.
Old 08-12-2011, 06:08 PM
Tech Guru
4Driver4's Avatar
If it's a massive leak, why is it so difficult to find?
Given that we can only guess, my guess is aux water pump.
Old 08-13-2011, 12:12 PM
jseklund's Avatar
Have you checked the rubber hose going from the resevoir to the coolant line in the back of the heads? This hose has braiding over it and that could make it difficult to spot a leak. What about the resevoir itself, as they are known to crack?
Like 4D4 said, if it's that big, it should be pretty easy to locate. I'd unscrew the resevoir, flip it over, look at it, and look at the hoses going to the back of the engine. Then I'd look at the coolant pipe to the back of the heads.
But as 4D4 said, since we can only guess...it could be almost anything.
Old 08-13-2011, 09:27 PM
tester123's Avatar
Just from the common sense angle, my thoughts are leading towards an obvious ruptured hose/fitting. Having said that, it can be difficult at times to find out exact origins of the leak. It is somewhat difficult to find a small leak but, if you are emptying out the tank quickly, things should not be that difficult to trace it. Trace the coolant hoses / route through the diagram and isolate the area. I know, sounds easy typing behind a screen but, that's what really going to help. It's not easy for any of us to pinpoint the leak over the forums as you can understand. Hope you find it quickly.
Old 08-14-2011, 02:04 AM
bigdadi's Avatar
Put some colorful or something flourecant can be identified by ultra violet light.
Old 08-14-2011, 04:34 PM
SloopJohnB@mac.com's Avatar
Yeah..that's the ticket with a massive coolant dump...Not.
Just find the ruptured hose or loose/broken fitting.
Quick Reply: Massive Coolant Leak near firewall
