Go Back   AudiWorld Forums » Audi Models » Audi Q3 /Q5 / Q7 » Q7 Discussion
Q7 Discussion Discussion forum for the Audi Q7 SUV
Sponsored by: Audi
Old 08-03-2011, 05:58 AM   #1
iconoclast
AudiWorld Expert
iconoclast's Avatar
Default Dash Bezel Removal...
Anyone here familiar with removing the silver bezel which surrounds the MMI screen?
I cannot find a clear cut answer and it is not similar to the a6 removal process.
by looking at it, it seems like the ch changer needs to be removed and the center vent then can be removed then get access to the t15 torx nut that holds in the bezel.
can anyone confirm or provide info?
iconoclast is offline   Reply With Quote
Old 08-03-2011, 11:35 AM   #2
Jusforfun
2007 Audi Q7
There was a post about this already. Just got to find the right keywords to search. Dont break anything mmeantime.
PS my M is sticking mmmmmmmmmmmmmmmmmmmmm nnnjjkk,must be bread crumbs... TMI
Jusforfun is offline   Reply With Quote
Old 08-03-2011, 05:29 PM   #3
iconoclast
AudiWorld Expert
iconoclast's Avatar
hahaha...
Old 08-04-2011, 03:19 AM   #4
DieselDave
The centre vent just pulls out, according to ELSA.
Get a flashlight down the inside of the vent and you should see a hole, one each side. A hook tool is used to latch in those holes and then pull it straight out.
I can't find anything that says how to get the bezel off though...
Now: 2011 A6 (C6) Avant 2.0TDi S-Line
Past: 2007 Q7 3.0TDi S-Line; 2006 A6 3.0TDi S-line; 2005 A6 2.0TDi SE
DieselDave is offline   Reply With Quote
Old 08-04-2011, 06:27 AM   #5
iconoclast
AudiWorld Expert
iconoclast's Avatar
thank you.
i was looking at the a6 and there are tabs on the inside of the vent. there arent on this one, so what you say makes sense.
if i get around to it this evening i will check it out.
Old 08-25-2011, 08:43 AM   #6
iconoclast
AudiWorld Expert
iconoclast's Avatar
apparently you need a certain vas tool to push the tabs down to pull out the center vent.
has anyone done it with out the specific tool?
Old 08-25-2011, 07:59 PM   #7
arp2nr
Default use 2 spring pullers
I used this to remove my center vent it is called a spring puller I got mine from ebay:
http://cgi.ebay.com/ebaymotors/Sprin...item2a0880bd5a
arp2nr is offline   Reply With Quote
Old 08-26-2011, 05:22 AM   #8
iconoclast
AudiWorld Expert
iconoclast's Avatar
thank you. will i need two and do them together or one at a time will work fine?
Old 08-27-2011, 06:05 PM   #9
arp2nr
you need 2 and do them together.
Old 04-26-2013, 03:57 PM   #10
henryt111
2007 Audi Q7
Default Dash replacement
Did you ever figure out how to replace the dash surround?
Henry
henryt111 is offline   Reply With Quote
a6, a8, audi, audiworld, bezel, center, dash, dashboard, forum, iconoclast, line, nnnjjkk, q5, q7, removal
