#1 | ||
#2 |
2004 Audi S4Join Date: Nov 2011
i know the runners are vacuum powered, not sure if theres any electrical to it. your best bet is a donor car..... gonna have to pay for that though.
#3 |
Depends on what 4.2L V8 your talking about too. The older 32v only had one vacuum actuator. The first 40v had 2 vacuum actuators for the flaps and also used electricaly actuated hydrolic timing chain tensioners to advance the intake cam that worked in conjunction with the ecu and cam timing sensors. Regardless you still have 8 injectors and 4 oxygen sensors to deal with too.
I'm guessing your still going to need the ECU and harness to make it work.
![]() 1997 A8 Quattro hot/cold 171,375 miles Tranny Dead! :-( Broken arm rest Broken cruise control (its a moot point now!) ![]() 2001 A8L Pearl White hot/cold Boss's Car (God She's Hot!) 87,774 miles |
#4 |
I'm sure the original poster is long gone, but I doubt this is do-able for a sane amount of $$$. Why not take the already trodden road that Monster Miata uses and go with a Ford V8? A marine 351W engine is good for 350hp normally aspirated. Throw a centrifugal supercharger on there and you've got your 500+hp and an existing blueprint for how to do the swap. 351W marine crate engines are pretty cheap....much cheaper than an Audi 4.2L (which is only good for about 350hp normally aspirated too).
Best,
--- 2002 A4 1.8TQM mod-free at the moment (gotta deal with that) Formerly...2001 A6 2.7T quattro 6sp w/GIAC X Before that...1999 A4 1.8T 5sp w/lots o mods |
#5 |
I looking for the ECU wiring diagram for a 1998 A8 as i am performing a 4.2 swap into a Pontiac fiero . I know there are better engines but this engine is nice and short better for longitudinal install plus if you want power these days just put a turbo on it
#6 |
I have the motor, and the ECU with wire harness for you if you want it. just give me a call and we can talk, I have a complete donor car if you need it. 301-379-2624 Mark
| Tags |
| 42, 42l, 8090, a4, allroad, audi, b5, b7, cabriolet, engine, mated, mazda, miata, s4, standalone, swap, t56, v8 |
