Airbag Fault Code 00589 - HELP!
This has become very aggravating... My 2000 Audi TT 180 FWD has had its airbag light on for months. I took it to a reputable Audi repair shop and they were stumped. I bought a VAG-COM and got the following readout:
Address 15: Airbags Labels: 8N8-909-601.lbl
Part No: 8N8 909 601
Component: Airbag Front+Seite 0005
Coding: 10102
Shop #: WSC 01236
VCID: F7F39C2CFF5D
1 Fault Found:
00589 - Airbag Igniter 1; Passenger Side (N131)
32-10 - Resistance too High - Intermittent
I read up in advance and purchased a handful of 4.7 ohm 1/2 W resistors for the airbag connector under the seat to trick the computer but I still got the same fault code immediately after I cleared it. I've also cleaned the connector. Not sure what I should do next.
Coding: 10102
Shop #: WSC 01236
VCID: F7F39C2CFF5D
1 Fault Found:
The resistor trick is only for the side airbags.... Sounds like the in-dash airbag unit is faulty.
I had the 4.7 ohm 1/2 watt but that didn't work so I figured the sensor under the seat was a different resistance. If the seat sensor gives me 4.7 ohms when I test it with multimeter then I would look at replaceing the airbag. What do you think?
You need to fix the underlying problem first, and likely have a dealer turn off the bag light...Often times a Vag or regular OBD2 tool won't clear that code.
I think I am following here. I just spoke with an Audi tech that's a friend of a coworker. He said to try the 4.7 ohm trick on the airbag connector in the glove box. There is a yellow connector in there just the same as the one under the seat.
My VAG-COM software clears the code for about three seconds (light in cluster goes off).
