Old 07-13-2011, 05:58 AM   #1
tester123
Default Fuel Bank 1 and 2 running lean
I am having this issue come up now where both fuel banks are running lean...
Is this related to MAF or other issues? I plan to check some vacuum / breather hoses that might have been missed from the last round... in the mean time, please share your insights.
01 Pearl White A6 4.2 Quattro
Sport, cold, everything except Nav.
TEMPORARILY PISSED OFF WITH ITS FUEL BANKS LEAN ISSUES...
tester123 is offline   Reply With Quote
Old 07-13-2011, 06:31 AM   #2
jseklund
If it's consistent across all banks, I would look for a vacuum leak first. The MAF and fuel pressure would be the next places I would look.
jseklund is offline   Reply With Quote
Old 07-21-2011, 12:22 PM   #3
tester123
Would a leak from oil cap / oil cap gasket do this? I am planning to replace this as it seems to be old - still looking ok though...
Old 07-24-2011, 06:52 PM   #4
tester123
Today, I checked a bit more on these vacuum lines and the one going to Fuel pressure regulator with those 90° rubber lines seemed to be a bit loose and replaced them and few others that looked on the verge to go. Still, I am coming back with same code, both banks lean. This is getting rather frustrating. I read here on of the threads about "suction valve", could this be a culprit?
Also, took one of the vacuum lines of the valves towards the front end driver's side and applied vacuum with hand pump and it is holding perfectly without leak.
There is a valve (EDIT: non return valve) looks like white and plastic discs joined and vacuum lines going on both ends. One side (white) is going to engine manifold and the other connected to rest of vacuum lines. Hand pump vacuum is very slowly dropping on one side and the other side it is open. Would this have any effect?
Old 07-25-2011, 06:33 PM   #5
tester123
Could someone please post a Complete vacuum diagram for 2001 A6 4.2 Auto? I can't seem to trace the vacuum leak (if there is one at least).
Apparently, the bentley manual (ebahn reader) I have only shows a complete diagram for 2.7T...
Old 07-25-2011, 07:12 PM   #6
meternerd
Fuel filter? I had an old Audi 90 and that's the code it gave when the filter was plugged.
meternerd is offline   Reply With Quote
Old 07-26-2011, 12:06 PM   #7
tester123
Don't have the tools required to conduct a fuel supply test... would have to wait until weekend for that. In the mean time, I checked the MAF and it seems to be within (4.56~4.65g/s) the specs (3.5 to 7.0 g/s) at around 720rpm under normal temp. Did not road test with the MAF sensor out of the air inlet plumbing to see if the results would vary. However, disconnecting it resulted in a noticeable shudder and loss of engine performance.
Even after multiple restarts, the code didn't come back again. It seems like it would happen only after a road test - which needs to be confirmed.
Old 07-26-2011, 07:32 PM   #8
Redneck Truck
Redneck Truck's Avatar
Uploaded with ImageShack.us
2001 A6 4.2Q 6MT
2001 TTQ TDI swap in progress
2001 TDI Jetta
2000 TDI Golf
2006 CBR1000RR
C5 tech, writeups, help blog.
Redneck Truck is offline   Reply With Quote
Old 07-26-2011, 08:52 PM   #9
tester123
Thank you for the diagram. Won't be able to test things until weekend; will post my findings.
Old 07-28-2011, 05:52 AM   #10
4Driver4
Tech Guru
4Driver4's Avatar
I agree. Vacuum leak is the most likely issue, followed by MAF. Fuel pressure is a distant third.
VAG-COM measuring blocks can be used to check the MAF, which may provide insight into MAF functionality or leaks.
4Driver4
"Never give up the throttle until the bitter end." -RC
2003 Mini Cooper S (Fun!)
1995 Mazda Miata: the anti-Audi
1999 Mazda Miata SSB: track beotch
2003 GMC Yukon Denali XL: the anti-earth
2004 Dodge Dakota: hey, at least it's stick and 4x4
1and, 2001, a3, a6, allroad, audi, bank, breather, fuel, hose, lean, running, tt, vacuum, wiki
