#1 | ||
#2 |
2012 Audi A4Join Date: Sep 2010
"... fuel too lean" is very likely refer to MAF.
Instead of cleaning MAF, replace the MAF sensor. Sometimes it still won't work just by cleaning.
12 A4 2.0T Quat(In 4/25/12) 02 A6 Avant 3.0 Quat(Out 4/24/12) 07 Outback 2.5i Ltd(Sold 5/4/12) |
#3 |
Thanks bigdadi, if it throws the lean error again I will replace it. So far after I cleaned the MAF it seems to be working without issue. Now if I can only figure out this "pressure light" problem.
#4 |
2002 Audi S6Join Date: Oct 2002
It is possible the new sensor you had/put on has failed. The only way to be sure is to monitor oil pressure separately with a mechanical pressure gauge..tap into the oil pressure where the sensor is and see what's what.
If you have adequate oil pressure you replace the sensor again. If you DON'T have adequate oil pressure you drop the pan, clean it and the oil pickup screen and probably replace the oil pump, put it back together again with thick oil in the pump, fill up the sump, spin the engine over with ignition disabled until oil pressure comes up, enable the ignition, and run the engine. |
#5 |
I had a similar problem on my 2002 3.0. The oil pressure light would come on randomly but the pressure was good. One of my mechanics thought it was the oil pump but my smarter mechanic said no way and told me to check the oil pressure sensor. It turned out that oil was leaking onto the sensor and getting into the electrical connection. I cleaned the plastic connection piece with a degreaser and let dry thoroughly and also bought a new sensor ( although I am not sure if a new sensor was needed since it may have just the oil in the connection). The part was cheap and purchased at autozone iirc. The sensor is easy to access from the front with a long extension. I think I also removed the driver side headlight for better access.
This also occured around the 80k mark and the issue has not returned at current, 126k. TWB |
#6 |
Also try using 5w-40 M1 Turbo Diesel or O-40 M1 Euro formula. Both Audi approved.
#7 | |
I drove the car for about 15 minutes, got the car up to temp and no error light. Knock on wood. I'm going to drive the car around without the plate for a few more days in case the light comes back on and if that's the case I'm going to have to drop the pan and see what's going on. I also bought some 0w-40 M1 Euro for that work. Thanks again. |
#8 |
Looks like I have to take the pan down and see what's going on as the light came on several times today.
I did some searching and couldn't really find much on replacing/removing the oil pan for a 2004 a6 3.0 quattro. Does anyone have any DIY tips or notes? I can do this I just want to make sure there are not "gotchas" that's I'm not aware of... Things coming to mind are: should the bolts be torqued to a spec or does that not matter? Gasket or sealant? Special kind/brand? Do I need to do anything special once I put the pan back on? Can I just put oil in and turn the car on? Thanks in advance. |
#9 |
I used "The Right Stuff" on my 2K4.2A6 oil pan and it worked fine.
Bentley says to cut the applicator tip to make a 1mm hole to apply a bead no thicker than 1.5mm around the lip of the oil pan and around the inside of the oil pan bolt holes. Thicker than that can allow the sealant to get inside the pan and clog the oil pickup (???!!!). The pan must be installed within 5 minutes of running the bead...so don't take all of your five minutes to run the bead!!! Install the pan with bolts finger tight, then diagonal-tighten then to 5 NM. Then final torque them to 10NM. Let the sealant set up for at least 30 minutes before filling/starting engine. I let mine set up overnight, I had other things to do. |
#10 |
DID YOU ACTUALLY CHECK THE OIL PRESSURE WITH A MECHANICAL GAUGE?
If you didn't you have no idea whether you have an oil pressure or sender problem. Dropping the pan can be useless although a fun exercise in cleaning sludge out of the pan. |
| Tags |
| 2002, 2003, 30, a5, a6, audi, c5, c6, filter, light, mobil, oil, pressure, sensor, tt, wrong |
