Go Back   AudiWorld Forums » Audi Models » Audi TT / TT-S / TT-RS » TT (Mk1) Discussion
Old 06-19-2011, 01:24 PM   #1
M-Tech TT
Default 2001 TT Roadster glove box repair
Recently while detailing the inside of the car my son-in-law broke the glove compartment latch. The latch is held in place by two pegs that the latch pivots on. The upper peg was still intact but the bottom one broke off. I've read on other forums where people have replaced the pegs with a rivot and JB weld. I believe my way is a little easier and just as strong. To perform the repair do the following:
1)Remove the interior panel of the glove compartment door by removing 6 out of the 8 torx headed screws. The reason I only removed 6 of them is because the final two where located where I could not get the torx socket on them. Even with the final two screws still in place you can pry the interior lining of the door open enough to get at the screws that are holding the latch bracket in place. I believe there were 4 (could have been 6 - I forgot) screws holding it in place.
2) Once the bracket is out drill a (slightly smaller than the screw to be used) hole just opposite of the peg that is still in place. If both are broken off then make sure you drill the holes right where the pegs used to be.
3)I used a #8 screw x about 3/8" long. You want it long enough to go through the hole you drilled in the plastic an protrude far enough to hold the latch in place. At first I was going to use a nut to hold the screw in place but by drilling a slightly undersized hole the screw threaded itself into the plastic and didn't need the nut.
It only took me about 30 minutes to do the job and saved me allot of $$$. I would recommend anyone trying it before you go and buy a whole new glove box door.
Photo's attached.
M-Tech TT is offline   Reply With Quote
Old 04-14-2012, 06:07 PM   #2
Flawxy
Default thank you
thank you sir, you are a saint. when i broke mine yesterday i freaked cuz i knew how much money the whole box is so ill try this tomorrow. both of my latches broke
Flawxy is offline   Reply With Quote
Old 04-16-2012, 08:00 PM   #3
M-Tech TT
Good Luck!! Be curious if it works for you. Mine is still holding.
Old 05-03-2012, 06:13 PM   #4
DenimPearlTT
I just bought my first audi 6 months ago... 2000 TT and when i bought it they told me the lock was in perfect shape. When the car arrived the lock came off in my hand I called them and made them pay the price of a glove box which they gladly did suprisingly. So instead of buying another glove box I fixed it with the steps below:
I opened the glove box removed the Gray caps on the screws first. Next i removed all the screws while holding the outside cover. Then i closed the glove box so i could remove the front cover of the glove box. Once the cover was off the first area that was broken was the center gear wheel that allows the glove box to open/close. So if you look close you can see where the wheels center plastic peice broke off... I drilled a pilot hole into the glove box then got a OEM audi screw for the glove box and screwed it from the inside of the glove box and then slide the gear into place then aligned the rods back into place. ( once front panel goes back on there is a notch that will hold the wheel on the screw it doesnt fall off )
Next the Notorious nubby arm that hold the lock was broken. I pulled the plastic peice off the front cover by removing the screws that were on the metal rod on the back of the front cover. Once off you can see that if its broken there is lighter color U shape from where the teeth broke off.... I again drilled a pilot hole but this time i got a rivot with a head on it. Instead of push it to have it expand i filed the holed till it slipped into place very tight then pulled it back out slid the lock into place then put the rivot back in so i could measue how long it would need to be. I filed the extra length of the top of the rivot head so it would sit flush on the bottom of the plastic panel then used JB weld to glue it in place ( NOTE : must put lock in first then slide the rivot in place ). Once this was complete and since my top tab wasnt broken i didnt do anything but would hve repeated the rivot steps for the top tab if it was broken. I reassembled the glove box and throughly test the lock assembly by pulling on it like I was trying to steal it and it didnt budge. 6 months later and numerous open / closes and even with it full and pushing on it hasnt failed at all and is 1000 times more durable then the plastic junk setup they did to cut down on cost... Cost me a whole 7 dollars for the 2 rivots and OEM audi bolt with gray cover so it doesnt show as i added the screw. Took about 2 - 3 hrs to complete the repair as im overly causous when it comes to fixing something right the first time.
Hope this helps you or anyone else out. Pictures are similar to post below sorry dont have them on this computer and same Idea for fixing...
DenimPearlTT is offline   Reply With Quote
01, 2001, audi, audiworld, aut, box, broken, compartment, glove, glovebox, gloves, latch, rapire, repair, replacement, roadster, tt
