Power door locks don't work
Old 06-11-2011, 09:11 AM
Delvekio's Avatar
Default Power door locks don't work
Hi everybody,
I just bought a '99 A4 2.8 Quattro. I'm new to Audi so I've got a lot of questions. I've only got one key, no remotes and the power door locks don't work. I can manually lock the passenger doors from the inside and lock the driver door with the key from the outside. I've scoured the forums and gotten all kinds of good information, but I guess I lack info like is this car equipped with a stock alarm and am I supposed to have a remote? I've read a great deal about the central locking pump but before I go for that could it just be a fuse or electrical issue in the door? The gas door remains unlocked as well.
Another stupid question: I've read in the manual about neat tricks you can do with the key like convenient roll down/up of the windows but this stuff is confusing when it doesn't work.
Any help is appreciated and thanks for taking the time to respond to something you've probably heard ten thousand times before.
Thank you!
Old 06-11-2011, 09:33 AM
Tech Guru
4Driver4's Avatar
If you are in the US, the car has a factory alarm and you should have a remote that is part of a switchblade key.
Old 06-11-2011, 10:01 AM
Delvekio's Avatar
I am in the U.S. but no remote or switchblade key. Do I have to go the dealer or is there a cheaper solution?
Old 06-12-2011, 08:34 AM
mtroxel's Avatar
Don't spend $$ on a remote till you get the power locks working. If you lock the driver's side door, everything else (including the gas door) should lock. In normal operation, you can hear the pump in the trunk behind the RR wheel. If you lock the driver's door and don't hear the pump, there's no point in buying a remote. You need to sort through that problem first.
Old 06-12-2011, 09:43 AM
CaptinGonads's Avatar
I have a 2000 A4 2.8 with a the same problem. The graphite disks in my locking pump are shattered.
Old 06-12-2011, 12:15 PM
Delvekio's Avatar
Okay I'll go check the pump first then. Thanks for the advice.
Old 06-12-2011, 01:02 PM
Delvekio's Avatar
Heres my pump. The graphite disk looks intact but the electronics are a little worrisome.
Old 06-12-2011, 08:37 PM
There are three disks. The outer ones are not likely to shatter but the center one that actually handles the pumping is divided into four quadrants held at a weak center point. If the pump stil hums when you lock the driver door with the key and the alarm is activated then that center one is probably done for.
Old 06-12-2011, 11:36 PM
MTykhnenko's Avatar
There is too much corrosion. Easily fixable if you have a soldering iron and some isopropanal along with a old toothbrush. Clean off all the corrosion with the alcohol and tooth brush, then restore all damaged conduits by scratching their surface off and putting solder in between.
Old 06-14-2011, 04:53 PM
Delvekio's Avatar
The disks are definitely shattered. But I still don't have power to the pump. Time to check some fuses.
thehox
12-06-2011 04:01 PM
younggunfordfan
12-02-2010 05:22 PM
spartan1
Audi 100 / A6 (C4 Platform)
08-02-2005 02:54 PM
z3b6hand
12-08-2004 07:58 PM
audivenom
03-30-2004 07:17 AM
Quick Reply: Power door locks don't work
