Go Back   AudiWorld Forums » Audi Models » Audi TT / TT-S / TT-RS » TT (Mk2) Discussion
TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-present
Old 06-04-2011, 08:15 AM   #11
GaBoYnFla
2011 Audi TT
How did they do the FLASH? Did they send off the ECU or just flash it right there? My dealer told me they would have to have the car 4-5 days. I'm not keen on leaving my car in their open back lot sitting there.
GaBoYnFla is offline   Reply With Quote
Old 06-04-2011, 10:43 AM   #12
SoSuMi
SoSuMi's Avatar
My APR flash was done on site. Took a little less than an hour.
Byron,
2011 Audi TTS Coupé APR Stage One
SoSuMi is offline   Reply With Quote
Old 06-04-2011, 01:11 PM   #13
jza80
2009 Audi TTS
I think it depends on the model year. My TTS is a 2009, they did the reflash at the dealer, it took about 90 min. Later MY need to have the ECU shipped in for reflash, I think.
jza80 is offline   Reply With Quote
Old 06-04-2011, 01:41 PM   #14
GaBoYnFla
2011 Audi TT
That's what I was told....I'd rather take the ECU out myself and ship to them keeping my car in my garage....I'll have to ask about that.
Old 06-04-2011, 10:34 PM   #15
jza80
2009 Audi TTS
Well I ran some 60-80 sprints today, but the result was not quite what I expected. The first run was a 3.20, and the best was 3.11 which is slightly quicker but that does not tell the whole story. For some reason, I was experiencing misfire/hesitation from about 5,300-6,500RPM. It usually manifested itself as 2 or 3 hesitation events in the run. For sure this messed up my times. It repeated almost every time. The strange thing is, if I do a standing or rolling sprint, there is no problem, including full throttle runs up a grade. But for some reason, doing the 60-80 timed runs, (starting at 50-52 or so), I get the hesitation. I put new NGK platinum plugs in before the tune, as the original Bosch plugs had 38.5k. I wonder if I need to use OEM Bosch plugs? Maybe the build up on my intake valves is causing this problem at specific ranges? Anyway, I'll have to do some investigation...
Old 06-05-2011, 05:10 AM   #16
Stevelev
Stevelev's Avatar
Wrong info ... When I was looking into flashes, all companies except for MTM said the ECU needed to be removed. In the US, you can rent the MTM flash tool but in Canada, the dealer is nearby and he came to me, plugged in and was done in under 30 minutes. It seems that APR "local" dealers have no clue but when speaking directly with APR, they confirmed that they too do not need to remove the ECU.
2010 Ibis TTS - Stage II + some other stuff
2011 Ibis Q5 - Bone stock
2004 VR MSM - some bolt ons
Stevelev is offline   Reply With Quote
Old 06-06-2011, 08:28 PM   #17
kendoist4162
kendoist4162's Avatar
APR doesn't need the ECU removed to do the reflash. If the APR dealer you are talking to says different, run away. Not walk, run.
kendoist4162 is offline   Reply With Quote
Old 06-06-2011, 10:23 PM   #18
GaBoYnFla
2011 Audi TT
I'm talking about STASIS-Audi partner in tuning....to preserve warranty.
Speaking of APR, I vaguely remember years back that you could get a stealth mode version that the dealer couldn't tell was there....does that still exist?
Old 06-13-2011, 08:34 AM   #19
JimInSF
JimInSF's Avatar
Wait a sec - are you saying Audi has agreed somewhere that a reflash, from someone, anyone, will not void your warranty? Links or it didn't happen.
JimInSF is offline   Reply With Quote
Old 06-13-2011, 10:20 AM   #20
Stevelev
Stevelev's Avatar
Fairly certain that Stasis covers issues relating to their mods AFTER Audi declines warranty.
060, 2011, audi, cpo, ecm, ecu, gti, perform, reflash, specs, stasis, tts, tune, upgrades, warranty
