| S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008 |
#1 | ||
2004 Audi S4Join Date: May 2011
#2 |
2009 APRILIA RSV1000RMy Garage Join Date: May 2003
How is it at idle?
need to gather more info to try and help stick shift? auto? possible to get a reading with a VAG com? check channels 14,15,16, and 17 for misfires. if no power loss and ok at idle check the front vibration damper, also seen the dual mass flywheel come off center and vibrate the car like hell.
AUDIDR.COM 2011 S550 fully loaded 2006 A6 3.2Q 2007 S4 for sale RSV1000R for sale 2009 A5 3.2 2008 A4 2.0 for sale 2013 APRILIA RSV4 |
#3 |
I've had a bad flywheel before on one
#4 | |
How many hours is the flywheel job? |
#5 | |
is begining to sound like a flywheel. double check with a mechanic, you may have to rotate the engine and apply pressure from the side to the fwheel to see if any movement. push it from the ring gear, should be no movement at all. good luck
#6 | |
#7 |
Banned
that's what I thought before I opened the thread. Bad B6 flywheel seperating.
Go JHM stage III clutch and LW flywheel OP. It will shed a few pounds rotating mass (13 lbs I think) and will give you a far better clutch setup as a bonus. |
#8 |
We will replace one tomorrow, will post pictures for everyone to see.
#9 |
I actually have the same exact problem and the guy I bought it from thinks it might be the engine mounts which I get in today. I really hope its the mounts cuz they were pricey but please let me know what it turns out to be and I will do the same.
Thank you |
#10 |
Here hope this give you an idea of what am talking about.
notice the center bearing with the white plastic ring around it, is off center and grease have been release all around.
| Tags |
| 04, 2001, 2004, audi, cel, check, engine, idle, light, lights, noise, s4, shake, shaking, shudder |
