Go Back   AudiWorld Forums » Technical Discussion » Motors » 12v V6 Discussion
Old 05-04-2011, 09:39 PM   #1
gigity2008
Default FAILED IAC valve (more commonly known as the Idle Stabilizer Valve, or ISV) HELP
My car was jump started last night and since then the car's RPM holds around 1600rpm
You can hear that the IAC is stuck open.... things havnt changed and its now the next day.
Has anyone had this issue?
ive done a VAGCOM scan and no errors are shown sadly can you run a scan with the car running?
ive called audiwreck in Oakleigh and the said it should stop doing it while drivin... But ive driven it time and time again for around an 40mins and sadly no deal.
I really dont want to pay a mechanic to ripp me a new1
its freakin me out... Please help
cheers case
gigity2008 is offline   Reply With Quote
Old 05-04-2011, 10:44 PM   #2
mdecsi
1996 Audi A6
I don't think jump starting has to do anything with a stuck ISV.
First check the solenoid with a DMM, you can do it on the car just by removing the cables. If it looks good, remove and clean it. There are plenty of instructions on how to do it. Here is one of them:
http://12v.org/maintenance/repairs/isv.php
You can also do a VAGCOM test to cycle on-off the valve. It makes a loud clicking sound as it opens and closes.
mdecsi is offline   Reply With Quote
Old 05-15-2011, 11:18 AM   #3
Luxus Panzer
Luxus Panzer's Avatar
Send a message via MSN to Luxus Panzer
cheers case
test it as the other dude said, then remove it and clean and lube it....you will most likely be GTG. Happens to most of us with a 12v once every 2 years or so
"Spartans never die" Spartan 051 - Kurt Status:MIA
Luxus Panzer is offline   Reply With Quote
05, 2000, 2003, a4, a6, a8l, air, audi, control, failed, iac, idle, location, stabilization, stabilizer, valve
