Go Back   AudiWorld Forums » Technical Discussion » Motors » Forced Induction Discussion
Old 04-24-2011, 01:34 PM   #1
vtraudt
Send a message via Skype™ to vtraudt
Default VAgcom logging - Engine load etc
I logged a few 3rd gear runs to determine what parameters can be logged and what they 'tell'.
For example:
"Engine Load": Group 2 - Field 1 -Engine - Load - ms. Climb to 10.5 ms at 4000 rpm, then fall to around 8 at 6.5k.
"Timing Retard": Group 20 - Field 0
Cylinder 1 - Timing Retard. Shows zeros for lower rpm, then 2.2 up to 3.7 for higher RPM.
1998 Passat 1.8T manual; Kraftwerk Turbo TM2, 550cc Bosch EV14, FSI coils, 3" MAF, 3" DP, high flow manifold, S4 clutch, single mass FW, FMIC, custom TIP, Kraftwerk Tune
1999 Passat 1.8T manual; Kraftwerk Turbo TM3, 550cc Bosch EV14, FSI coils, 3" MAF, 3" DP, custom TIP, FMIC, Kraftwerk Tune
2002 Audi Allroad 2.7T quattro manual; Kraftwerk Turbo TM4, 750cc Bosch EV14, FSI coils, stg 5 clutch, FMIC
2001 Audi Allroad 2.7T quattro manual; custom stg 1
1996 Audi A4 2.8 quattro automatic. Stock. Issues: heated seats not working (from neer model), ignition lock/key hangs, TERRIBLE gas mileage.
www.regulatorfix.com
www.kraftwerkturbo.com
vtraudt is online now   Reply With Quote
Old 04-24-2011, 02:21 PM   #2
vtraudt
Turbo is a K03/K04 hybrid, chip is 'T.A.P. Stage 2'. Stock injectors.
And since 'timing' is (?) an important parameter, what module/channel would be the one to log?
Intake air temp: I made several 3rd gear pulls to 6.5k, and several 4th mid rpm WOT pulls. IAT once reached 40 deg C, but mostly maxed out at 35 deg C.
Waste gate N75 duty cycle: starts at 99% up to 3k, then falls quickly to 78% before 4k and tapers to 60%. Does it mean (lower numbers)that N75 is bleeding off/reducing boost? Because running too lean? To prevent misfires? To keep boost under a certain given value?
Specified Torque is always 410 Nm. Does not seem to valuable info.
Actual Torque: peaks at 4k rpm with value around 215 Nm, falling to 170 at 6.5k rpm. Since it seems a calculated value: how does the value compare to 'reality'?
Old 04-25-2011, 05:29 AM   #3
vtraudt
Default 2 logs
For test purposes, I logged 2 sets of data.
Which parameters can be dropped, which should I add?
Is 031-1 Lambda current value of interest? Other 031?
HP is calculated from torque. Airmass/per HP ditto.
Old 10-29-2011, 10:44 PM   #4
A4Audi4Fun
2008 Audi A4
http://www.vaglinks.com/OBDII/Vag-co...d_Graphing.pdf
See if this download helps you.
(CDN - Special Edition 2008 B7 Avant 2.0T S-Line Dolphin Gray 6MTQS)
A4Audi4Fun is offline   Reply With Quote
031, 18t, 20, audi, channel, engine, hybrid, k04, load, log, ms, tfsi, turbo, vag, vagcom
HTML code is Off
