#1 | ||
1998 Passat 1.8T manual; Kraftwerk Turbo TM2, 550cc Bosch EV14, FSI coils, 3" MAF, 3" DP, high flow manifold, S4 clutch, single mass FW, FMIC, custom TIP, Kraftwerk Tune 1999 Passat 1.8T manual; Kraftwerk Turbo TM3, 550cc Bosch EV14, FSI coils, 3" MAF, 3" DP, custom TIP, FMIC, Kraftwerk Tune 2002 Audi Allroad 2.7T quattro manual; Kraftwerk Turbo TM4, 750cc Bosch EV14, FSI coils, stg 5 clutch, FMIC 2001 Audi Allroad 2.7T quattro manual; custom stg 1 1996 Audi A4 2.8 quattro automatic. Stock. Issues: heated seats not working (from neer model), ignition lock/key hangs, TERRIBLE gas mileage. www.regulatorfix.com www.kraftwerkturbo.com |
#2 | |
1995 Audi 90Join Date: Oct 2008
#3 |
there's no low port on the 96 A4(AFC) system. it was design so an audi mechanic services it.
#4 |
How do "audi mechanics" charge the system?
Open the lines at the compressor (or other location), make an adapter (they use machines to charge the systems) to connect machine to the system? How do 'HVAC shops' do it?
#5 |
are we sure there is not a port on the cabin side of the firewall??
So much knowledge lost in the "change over" but I remember something about a hidden port on the cabin side.
"Spartans never die" Spartan 051 - Kurt Status:MIA |
#6 |
well if it helps i found this out several years ago, get the mastercool 82272 adapter online for around 10 bucks and bridge the gap in that sensor and there you go you can refll the a/c at your will.
#7 |
2007 Volkswagen TouaregMy Garage Join Date: Jun 2008
That's it, and available through NAPA. Unscrew the low-pressure switch (on larger aluminum tube, next to cabin air filter) and replace with this adapter. Don't worry about venting refridgerant, there is a valve in the aluminum pipe's fitting. Jumper the low pressure switch connector's two sockets, start the engine and turn on AC, charge with R134a kit as usual. I have one with the integral gauge.
1996 Audi A4 2.8 1972 Datsun 510 |
#8 | |
#9 | |
But I cannot confirm your specific question: 'is there a valve' (to prevent bleeding the system).
#10 |
Yep, just like a tire valve. Just disconnect the electrical connector, unscrew the pressure switch (17mm wrench I think). You might get a puff of freon when it comes off, but don't worry about it. My only other advice is to roll off the O-ring from the threaded fitting, because it can be damaged by the adapter. Just screw the adaptor in, it doesn't need to be very tight, and then make a jumper to bridge the two contacts of the connector to make the compressor clutch work.
| Tags |
| 18, 1996, 2001, 96, a4, ac, audi, connector, high, low, nipple, port, pressure, switch, tt |
