Go Back   AudiWorld Forums » Technical Discussion » Motors » 4.2 V8 Discussion
Old 03-16-2011, 08:01 PM   #1
imallstressed
Default Cam adjuster question 2002 A8L
I have a 2002 4.2 A8. The cam tensioner is stock down. I should move by hand from this position, correct?
imallstressed is offline   Reply With Quote
Old 08-11-2011, 01:31 AM   #2
willywacken
2000 Audi S6
Under normal conditions, the camshaft adjuster should be locked in neutral position. If not, the locking bolt (meant to prevent noises during engine start) inside is broken.
So you should NOT be able to move it with your fingers.
willywacken is offline   Reply With Quote
Old 08-11-2011, 01:47 AM   #3
willywacken
2000 Audi S6
Addition: you should NOT be able to move it with your fingers, when it is not broken. If it is stuck in performance position, the solenoid valve (steering the adjuster) will probably keep it down, since there is still oil in the adjuster. The locking bolt canīt be repaired, next step should be the replacement of the whole adjuster...
2002, 2003, 2005, a8, a8l, adjuster, adjustors, audi, belt, cam, imagies, rear, s8, stuck, v8
HTML code is Off
