40V Intake manifold fix for stuck or sluggish flap pivots (no broken parts)...
40V intake changeover repair...stuck pivots
The answers you seek are now in the correct location...Quattroworld >>>
quattroworld.com Forums: 40V Intake manifold fix for stuck or sluggish flap pivots ( w/no broken parts )...
Ditto, thanks. Just heard back from Scott while it's under the knife at his shop and he reported one snapped rod and sticky flaps. Will see if he can run through your well documented procedure.
Snap!
That's with 142k miles on the odo, a good 100 or so of them in salty Michigan.
Cheers,
Keith
Snap!
Cheers,
Keith
well that was an adventure.
on my 2000 A8, both actuators are stuck in the stage 1 low speed position. Really stuck: I spent an hour wiggling, spraying, prying, and cursing at one of them and I couldn't get it off. Whats more, the upper spindle is very weak, the aluminum has corroded so much so that the upper triangular stop had actually rotted away. Looks like I'll be hitting ebay...but at least I now know why I have no highway power
Whilst looking over the Bentley, I stumbled on something that I (for one) did not know. I knew that S8's have different manifolds, with shorter actuating rods, different pivot placement, etc... What I didn't know is that S8 manifolds are 2 stage...both vacuum pods remain evacuated (both levers pulled back) from idle to 5400 rpms, when both release simultaneously, switching from long to short runners....unlike the A8 manifold which releases pods separately, at 3360 & 5200 rpms, long-medium-short runners...3 stages.
Some of the S8/S6 share inlet manifolds depending upon the engine build date but I think for the most part the 4.2 S cars manifolds are essentially the same.
If your flaps are sticky then you will need to disassemble the intake and clean it. Over thousands of miles and many year these collect oil and other nasties.
Some interesting info, BUT The interior flaps of the manifold do not get stuck...by design, there's nothing in there really to get stuck...doors with rubber gaskets, opening and closing.
Oil "build up" from the PCV system is the main cause of ANY "intrusion" and it does NOT hinder interior operation..in fact it is the ONLY way that the inner pivots (rear...never a problem)get lubricated.
There's a first time for everything just because you don't experience it or you don't believe it, doesn't mean it hasn't happened. A different manifold fixed the issue BTW.
Thanks for the info.
Wit my 2000 A8, the corrosion is so bad it has turned the aluminum pieces into a dark gray crumbly substance. the pieces that fit into the manifold snapped off clean at the manifold.
Luckily I found a manifold on ebay last week for $100
