Go Back   AudiWorld Forums > Audi Models > Audi S4 / RS4 > S4 / RS4 (B5 Platform) Discussion
Old 03-05-2011, 06:13 AM   #1
dimitris1453
Account #: 191198
Send a message via Skype™ to dimitris1453
Default torque converter removal?
hi anyone can help as far remove torque converter from 2.7t engine-tranny any tips for install new one
and do i buy the audi oem or rebuilt this one or buy one from some online stores?
got my engine out i think i need rear seal oil is everywhere...
thanks dimitris
2001 allroad <--under construction
2003 m3 supercharged 550+++
2002 range rover
2000 ml55
1999 nsx
2002 nox!!!
2001 996s
dimitris1453 is offline   Reply With Quote
Old 03-06-2011, 06:03 AM   #2
complacentsee
Account #: 94510
Get a 24mm socket to turn the crank. You need a T55 torx to remove the torque converter from the flex plate. There is a small inspection hole on the bottom of the engine. Rotate engine until you see a torx and remove it, repeat twice more.
I suck @ spelling & typing.
QW & AW B5S4 PWOTY.
complacentsee is offline   Reply With Quote
Old 03-09-2011, 07:25 AM   #3
dimitris1453
Account #: 191198
ok i did thanks..
any tips as far put new one on or geting a rebuild one?
as far put in do i nstall it on engine side or keep it in tranny and then bolt it when i put engine in place?
2002 range rover
2000 ml55
1999 nsx
2002 nox!!!
2001 996s
Old 03-09-2011, 09:01 AM   #4
complacentsee
Account #: 94510
Originally Posted by dimitris1453 View Post
ok i did thanks..
You must install it onto the transmission, and properly seat it first. There is a spec for this.
Basically you place it on, and rotate and keep pushing in, eventually it will bottom out with allt he splines properly engauged. If you do not do this correctly, the fluid pump will be crushed.
QW & AW B5S4 PWOTY.
27, 27t, allroad, audi, converter, disconect, drive, install, plate, removal, removing, tips, torque, torx, transmission
Forum Jump
