Go Back   AudiWorld Forums » Audi Models » Audi Q3 /Q5 / Q7 » Q7 Discussion
Q7 Discussion Discussion forum for the Audi Q7 SUV
Sponsored by: Audi
Old 02-25-2011, 01:46 PM   #1
zerophat
Default Factory rotors
Does anyone know factory rotor weight is on the 2008 v8 4.2? I thought that the brakes rotors were different between the engine variants.
zerophat is offline   Reply With Quote
Old 02-25-2011, 06:29 PM   #2
TJK
I know you said weight, but do you mean rotor thickness?
TJK is offline   Reply With Quote
Old 02-25-2011, 07:29 PM   #3
Jusforfun
2007 Audi Q7
Its the same for all models except the V12 TDI
Jusforfun is offline   Reply With Quote
Old 02-25-2011, 07:55 PM   #4
zerophat
Was looking at replacement, lighter than stock, but don't know what to compare?
Old 02-26-2011, 05:38 AM   #5
docman_md
Mine just reached 30K miles. I replaced all four rotors with StopTech Slotted (http://shop.achtuning.com/StopTech-1...s-Audi-Q7.aspx) and pads with Carbotech Bobcat. Better grip, no squeal, and no dust. Highly recommend this to anyone considering/needing to change rotors and pads.
2002 A4 3.0 Avant, Dolphin Grey/Black
2009 Q7 3.6, White/Beige, retrofitted LEDs
docman_md is offline   Reply With Quote
Old 02-26-2011, 06:49 AM   #6
GRNMACHINE
2007 Audi Q7
docman,
Do u know where the rotors/pads were manufactured?
GRNMACHINE is offline   Reply With Quote
Old 02-26-2011, 08:21 AM   #7
docman_md
StopTech is based in California and they do manufactured from there. They produce several of the big brake kits for Audi. Check their website (www.stoptech.com)
CarboTech is based in North Carolina. They also manufacture from there. I was weighing on Hawk LTS pads but the tuning shop here in Maryland recommended Carbotech Bobcat series. www.ctbrakes.com
I love this set up so much i am thinking about doing the same for my A4.
Old 02-26-2011, 11:51 AM   #8
Jusforfun
2007 Audi Q7
and they look so cool
Old 02-28-2011, 02:33 PM   #9
zerophat
So, lighter, same, heavier than the stock rotors?
Old 02-28-2011, 04:32 PM   #10
Reggie
AudiWorld Expert
2011 Audi Q5
My Garage
Reggie's Avatar
Just so you understand. Reducing the weight gives you better unsprung weight which helps handling but in a car the size of the Q7 you loose the ability to absorb heat in braking - going to a lighter disc can impact heavy use of the brakes in mountains and hard driving unless one makes up for it with a bigger diameter rotor and better pads.
Reggie is offline   Reply With Quote
2005, 2009, a4, a8, audi, b7, factory, long, rotor, rotors, thickness, weight
